turbo RSX fuel delivery ?s
Old Sep 2, 2003 | 05:51 PM
xci_ed6's Avatar
Default turbo RSX fuel delivery ?s
I just joined a race team (Formula SAE) and one of the guys has a base model RSX that he just put a turbo on, and is now having some problems. Basically the car leans out massivly after 3500 RPM. He has an inline pump installed (MSD) but I am wondering on the correct way to do this (since it is a returnless system, right?), and the way he was told to do it seems very odd. He also has a "black magic" piggyback box with a S-AFC-II. The black magic cuts the MAP voltage sso the SAFC can be programmed from 00%, making it easier to see the fuel trim.
The questions:
1)how do you run a returnless system?
2)Is a aftermarket FPR necessary?
3)What should fuel pressure be?
4)Is the primary O2 heated (1 or 4 wire)?
I am not new to turbos or Hondas (see sig) but am to RSXs, so please don't dismiss me as a retarded newb. I did look at the car and there really is a turbo, it is apperently a ballbearing T3/T4 and he is running a DeltaGate wastegate. I will find out the kit manufacturer for anyone interested ASAP (he told me, I forgot).
-Dustin
Old Sep 2, 2003 | 05:53 PM
xci_ed6's Avatar
Default Re: turbo RSX fuel delivery ?s (krustindumm)
forgot, he is also running 550cc injectors.
-Dustin
Old Sep 2, 2003 | 06:02 PM
duckywucky's Avatar
thats gotta be the cybernation turbo
try changing the spark plugs... i had the same problem.... this helped....
and tell him to make sure the battery is connected properly! dont want to burn down the car
Old Sep 2, 2003 | 06:09 PM
xci_ed6's Avatar
Default Re: turbo RSX fuel delivery ?s (duckywucky)
alright, any idea about the fuel system?
-Dustin
Old Sep 2, 2003 | 06:12 PM
duckywucky's Avatar
the fuel should be fine... i had the problem of it running lean at 3500
this was fixed by changing the spark plugs.... if i remember
Old Sep 2, 2003 | 06:16 PM
xci_ed6's Avatar
what to? just stock? what about gap?
Is there supposed to be a FPR on there, because he has none at all from what I can tell.
-Dustin
Old Sep 3, 2003 | 08:11 AM
xci_ed6's Avatar
We are going to check the way the lines run into the tank. If anyone has some advice....
From what I can tell he has NO FPR at all. I looked in the spots normal for a 'teg though. If it is a in-tank FPR, than there could be one. Should an aftermarket FPR be used with an inline pump?
-Dustin
Old Sep 3, 2003 | 02:53 PM
k-series's Avatar
The Cybernation kit INCLUDES a return fuel line.
My engine shot (blue return line):
And close up...
I don't know about the install specifics, but you can call Cybernation at 954-523-8483.
Steve
TheHondaFreak
Jul 15, 2005 12:42 AM
mister2racer
May 21, 2005 07:13 AM
Cannabis
Feb 6, 2004 01:16 PM
T3
May 1, 2003 05:08 PM
rsx-vt
Mar 15, 2003 08:44 PM
