what size turbo should i run???
Old Sep 2, 2003 | 05:07 PM
cliff666's Avatar
Default what size turbo should i run???
i am lookin for a good size turbo to run on my 95 ls block. my goal is about 250 @WHP @ about 12 psi stock b18b engine. would a t3/t04-e(i hope i said it right) be too big if so then what turbo should i run, i am also still undecided if i should run hondata or afc hack so any suggestions and info would be cool....
thanks
cliff
Old Sep 2, 2003 | 06:30 PM
Turbocivic94's Avatar
Default Re: what size turbo should i run??? (dragboy)
U should be fine with t3/t4e and use hondata. Both items will give u room for future
Old Sep 2, 2003 | 06:38 PM
VisualAutoMotoring's Avatar
Default Re: what size turbo should i run??? (25 PSI CRX)
run the T3/T04E....your budget allowing...go Hondata but SAFC hack works just as well
Old Sep 2, 2003 | 07:20 PM
cliff666's Avatar
but will boosting that big of a turbo what will full boost hit at?????with stock internals??????will i be safe boosting at 12 psi also with hondata or afc hack????i will be using 2 headgaskets with arp headstuds too but also lookin into what size injectors should i use.....
Old Sep 2, 2003 | 07:23 PM
MiraiZ's Avatar
Spool time may be a problem on an LS engine with that big of a turbo....I think you're looking at 5000-5500ish 'til you reach full...I think most LS guys run t3/t4b .48 AR
Old Sep 2, 2003 | 09:09 PM
T4eg's Avatar
Default Re: what size turbo should i run??? (MiraiZ)
250whp should be fairly easy with stock internals.
Old Sep 2, 2003 | 10:06 PM
igotyofire's Avatar
Default Re: what size turbo should i run??? (BlueHatch00)
so a t04b will spool faster, but wont make as much power as t04E compressor would? is what it sounds like your saying?
Old Sep 2, 2003 | 11:18 PM
Kack's Avatar
Default Re: what size turbo should i run??? (igotyofire)
Man, If I were you I wouldn't get the T3/T4 hybrid. It does take a long time to spool. With my F23 engine(stock with 140 hp 140 Tq) full boost comes in at 4,000 rpms. Any rpm below that is SLOW as hell. Its bearable on my engine...I just need to learn to keep revs up...but your engine is smaller...i dunno.
Old Sep 3, 2003 | 07:41 AM
igotyofire's Avatar
Default Re: what size turbo should i run??? (Kack)
and what are the turbo specs you have on your accord
2fast4urass
Jan 26, 2010 05:38 AM
bb6guy
Nov 24, 2009 05:47 AM
redlseg
May 6, 2005 09:31 PM
jfoster
Mar 19, 2004 07:14 PM
5STAR3
Feb 18, 2004 01:00 PM
