cooling system...
Old Sep 1, 2003 | 04:09 AM
92KillerBee's Avatar
Default cooling system...
when im driving like for a long time or lets just say if i drive my car too much around it start geting hot,it overheat,but when i turn on the heater it goes back down, is that my thermostat thats is going bad?
Old Sep 1, 2003 | 09:52 AM
NonovUrbizniz's Avatar
Loved
Default Re: cooling system... (92KillerBee)
It could be the thermostat...
If one of the hoses to your radiator is cold and the other is hot it's your themostat... if not then it's a cooling problem.
Old Sep 1, 2003 | 10:00 AM
Foozball26's Avatar
Default Re: cooling system... (NonovUrbizniz)
check your coolant level
You may also have air in the system.
Old Sep 1, 2003 | 10:38 AM
slvrcivic97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92KillerBee &raquo;</TD></TR><TR><TD CLASS="quote">when im driving like for a long time or lets just say if i drive my car too much around it start geting hot,it overheat,but when i turn on the heater it goes back down, is that my thermostat thats is going bad?</TD></TR></TABLE>
Actually, I think I read somewhere that that is 100% normal. They said that turning the heater on, actually cools down their engine.
Old Sep 1, 2003 | 10:52 AM
mmuller's Avatar
Mad Scientist
Default Re: cooling system... (slvrcivic97)
yes, the heater helps the cooling system, but its not normal it shouldnt be overheating. as they sayd before check for air in the system, thermostat, and make sure coolant is full.oh yeah water pump might be going bad
Old Sep 1, 2003 | 12:23 PM
Default Re: cooling system... (mmuller)
i was cheking everything today and it was something so simple....lol
my fan wasnt turning on.i fixed it and now its not overheating hopefully it stays like that.if not i tell you guys what happened.
thank you!
Old Sep 2, 2003 | 07:17 AM
~~~InNeEdFoRsPeEd~~~'s Avatar
* B A N N E D *
do you guys know what turns the fan on? is it the thermostat? or does it have some kind of temp gauge that when temp reach a certain point, it sets the fan on?
Old Sep 2, 2003 | 08:53 AM
Loved
Default Re: cooling system... (~~~InNeEdFoRsPeEd~~~)
your fan switch does...
here's a link to a mugen one... (it's lower temp than stock)...
http://www.kingmotorsports.com...ngine
it's the second item...
EK9JSPEC
12
Sep 1, 2012 08:51 AM
importfanatic17
Jan 4, 2007 09:14 PM
kb58
Aug 2, 2006 10:40 PM
s1ngle
Dec 12, 2005 05:26 AM
budget
41
Aug 5, 2005 09:11 AM
