how do i remove and install a main seal?
Old Aug 16, 2001 | 08:01 PM
Lei Siew Long's Avatar
Default how do i remove and install a main seal?
does anyone know how difficult this task would be and is it necessary. i've read in a mag that everytime a clutch is replaced it is necessary to remove the seal. but not sure if this is true and worth the trouble so, i'm seeking the advice of others. thanks.
Old Aug 17, 2001 | 10:08 AM
keithv's Avatar
Default Re: how do i remove and install a main seal? (boostedeg6)
I think the only things left to remove after the tranny and clutch/flywheel/pressure plate are gone is the oil pan. I think once the pan is off, you can slide out the main seal and put a new one back on.
I could be wrong though.
Old Aug 17, 2001 | 01:54 PM
Default Re: how do i remove and install a main seal? (breaka_1_9)
i thought the rear main seal is on the tranny.
Old Aug 17, 2001 | 02:02 PM
BreakStuff's Avatar
New User
Rear Main Seal is on the engine bock.. If it ain't leaking, don't screw with it!
Old Aug 17, 2001 | 02:13 PM
earl's Avatar
If it is not leaking now, don't replace it even if the clutch is already out. If it's leaking now, you must replace it as it will mess up the clutch. Just pull the cover off. (You may have to pull the pan completely off to do this or at least loosen it enough to pull it down where it attaches to the rear cover). Then have a new seal installed.
Old Aug 19, 2001 | 06:59 AM
CardDealer's Avatar
Banned
Default Re: how do i remove and install a main seal? (earl)
Modified by CardDealer at 4:17 AM 11/16/2006
Old Aug 19, 2001 | 05:35 PM
earl's Avatar
Default Re: how do i remove and install a main seal? (schlit)
When you say main seal, you are talking about the seal in the ENGINE that keeps engine oil from coming out where the crankshaft exits the block. If you have oil on the front of your trans, that seal is called the main shaft or imput shaft seal. Once again, if it is not dripping on the ground on a regular basis, I wouldn't mess with it. All those seals will sweat a minor amount of oils thru the years. No big deal. But if the leak on either seal is so bad that it throws oil all over the place and seaps onto your pressure plate, then it'd time to replace them. Sounds like you're OK.
Earl
grampswrx
Jan 4, 2016 09:32 AM
rogue420
14
Jul 18, 2010 05:44 PM
JDMPower98cp
Jan 2, 2006 12:11 AM
Do_Ster
Jan 14, 2005 08:23 AM
0ptimus prime
12
Jul 18, 2004 01:29 PM
