H22 Idle probs (already searched)
Old Aug 29, 2003 | 12:12 PM
Kp_VtekNiks's Avatar
Default H22 Idle probs (already searched)
im having idle probs where my h22 just wants to die. it was running on three cylinders the other day but i got that fixed, but now the idle is at like 100 and it just wants to die./ only reason the idle is even at 100 is because i turned the idle screw all the way up. car is running really rough sounds almost like a v8 at times. got the motor comp. and leakdown tested and everything was fine. changed plugs and wires, got the injectors checked out everything is fine. what could be the prob? could it be Fast Idle Thermo Valve? ive changed the tps and the map. could it be o2 or the timing? any help would be great thanks
Old Aug 29, 2003 | 12:39 PM
skunk2lude01's Avatar
try changing you distributor cap, it sounds like a possible misfire./
Old Aug 29, 2003 | 01:09 PM
Default Re: (skunk2lude01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2lude01 &raquo;</TD></TR><TR><TD CLASS="quote">try changing you distributor cap, it sounds like a possible misfire./</TD></TR></TABLE>
ok i'll give that a try. also whenever i take off the plug wire in the #1 cylinder it doesnt do anything, like the engine doesnt sound any diffrent etc.
Old Aug 29, 2003 | 02:04 PM
del_parker's Avatar
Default Re: (Kp_VtekNiks)
sparkplug?
Old Aug 29, 2003 | 06:10 PM
Default Re: (del_parker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">sparkplug?</TD></TR></TABLE>
there brand new
Old Aug 29, 2003 | 06:42 PM
IloveNewt's Avatar
Default Re: H22 Idle probs (Kp_VtekNiks)
fast idle, check it.
Old Aug 30, 2003 | 12:52 AM
Gerhard_001's Avatar
If your car is running that bad the Ecu should be throwing a code out telling you what the problem is. Your Ecu could be bad, your fuel pressure regulator may not be functioning correctly, fuel filter may be clogged, fuel pump may be going out, could be a number of things. Best advice is to check what codes the Ecu is throwing out, if it OBD 1 there will be an LED that flashes a certain amount of times to indicate what code, if it is OBD2 you will have to take it to a dealer or have a code reader to hook into it to read the code it is throwing out. .
Old Aug 30, 2003 | 04:29 AM
Default Re: H22 Idle probs (9SpreludeH8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9SpreludeH8 &raquo;</TD></TR><TR><TD CLASS="quote">If your car is running that bad the Ecu should be throwing a code out telling you what the problem is. Your Ecu could be bad, your fuel pressure regulator may not be functioning correctly, fuel filter may be clogged, fuel pump may be going out, could be a number of things. Best advice is to check what codes the Ecu is throwing out, if it OBD 1 there will be an LED that flashes a certain amount of times to indicate what code, if it is OBD2 you will have to take it to a dealer or have a code reader to hook into it to read the code it is throwing out. . </TD></TR></TABLE>
no cel's, ecu is good, going to buy a new fpr and fuel pump, but might need to change the filter since i have never done that yet.
Old Sep 1, 2003 | 01:54 AM
i need help! TTT
cfoland
Feb 19, 2011 08:33 PM
dointhemzs
Sep 7, 2008 07:09 PM
dek1mfk
Nov 20, 2006 02:56 PM
Kp_VtekNiks
18
Sep 16, 2003 12:10 AM
