Shifter is EVERYWHERE.... help needed
Old Aug 28, 2003 | 02:23 PM
mz3bo's Avatar
Default Shifter is EVERYWHERE.... help needed
Alright, i had all the bushing changed on the shifter linkage, including the one that hold the shift stick. still, when I am in gear, I can move the shifter all over the place, like if it were not in gear. worst, when I am in neutral, i can ''almost', make a full circle movement with the shifter ... But the gears and everything is A1, I am not missing nothing to the rod assembly. Anyone knows what can be wrong, it is in a 95 integra automatic now manual with b18b engine and tranny OEM.
Thanks
Old Aug 28, 2003 | 02:30 PM
RCautoworks's Avatar
Default Re: Shifter is EVERYWHERE.... help needed (mz3bo)
Its usually the joint at the end, head over to rpiracing.com and talk to them about it. They had a solution for it, it was not cheap though.
Old Aug 28, 2003 | 03:14 PM
.xcalibur.'s Avatar
maybe the spacer on the shifter wasnt installed. And you have too much play. Either that or the nut holding the bolt is lost.
Old Aug 28, 2003 | 03:34 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Shifter is EVERYWHERE.... help needed (.xcalibur.)
check the retaining pin that attaches the linkage to the transmission.
stan
Old Aug 28, 2003 | 09:03 PM
mz3bo's Avatar
Default Re: Shifter is EVERYWHERE.... help needed (90crxsi)
I am sure everything is tigh and correct.. my concern is, can it be inside the tranny ? because the gears don't grind or no special noise... it get into gears real great...
Old Aug 28, 2003 | 09:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mz3bo &raquo;</TD></TR><TR><TD CLASS="quote">I am sure everything is tigh and correct.. my concern is, can it be inside the tranny ? because the gears don't grind or no special noise... it get into gears real great...
Did you skip over my post ? I told you what the problem most likely, and now they you said everything else it tight, its most likely the joint. There is no way you can really tell the joint is bad by wiggling it, they get old over time. The only way you will really know if its the joint is if you get it replaced.
Old Aug 28, 2003 | 10:07 PM
mmuller's Avatar
Mad Scientist
Default Re: Shifter is EVERYWHERE.... help needed (90blackcrx)
have you checked:
have you checked #8 and #11?
Old Aug 29, 2003 | 05:03 AM
mz3bo's Avatar
90blackCRX: following the pic posted by another member, can you tell me wich part you are talking about? Because like I told you, there is nothing missing in my setup compared to the pics and there is nothing loose. all the bolts and screws shown are there and tight.
And yes... #8 and 11 is there and in good condition.. new parts...
Old Aug 29, 2003 | 07:03 AM
part 28, mine was crushed, and i found only after i had to take the entire assembly apart for bushings install. even a slightest play in that pin will result in a sloppy shifter.
stan
Old Aug 29, 2003 | 09:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mz3bo &raquo;</TD></TR><TR><TD CLASS="quote">90blackCRX: following the pic posted by another member, can you tell me wich part you are talking about? Because like I told you, there is nothing missing in my setup compared to the pics and there is nothing loose. all the bolts and screws shown are there and tight.
The joint I'm talking about is right by the shifter pin #28 . That little part wobbler's back and forth. Well the people at rpiracing.com have found a way to fix it by using a different type of joint.
Old Aug 29, 2003 | 12:32 PM
mz3bo's Avatar
Alright... part #28 had been changed... stil the same problem... what's now... is it inside the tranny, but remember how the tranny was doing good...
I am lost...
Thanks for you help
Old Aug 29, 2003 | 12:43 PM
AssPenny's Avatar
I had the same problem with my tranny... Turned out the 3 bolts that hold the shifter assembly inside the tranny worked there way loose. Hopefully thats not it, but for me, that was the problem. All three were loose and 2 were almost half way out.
Two of the bolts are circled here, the other one can't be seen.
Old Aug 29, 2003 | 05:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mz3bo &raquo;</TD></TR><TR><TD CLASS="quote">Alright... part #28 had been changed... stil the same problem... what's now... is it inside the tranny, but remember how the tranny was doing good...
I am lost...
Thanks for you help
I did say it was part #28, I said it was buy part #28. Its what the pin goes into. Here its this thing.
http://www.we-todd-did-racing....DE%3D
Old Aug 30, 2003 | 11:25 AM
The OEMobile's Avatar
I had the same problem after i did my swap. My shifter was really loose and i could pull it up and push it down,along with a ton of slop between the gears and a ton of looseness. If yours is also able to do that you might have the same problem. My problem was there was no bushing on the bolt that is right under the shifter holding it down. So the bolt was tight and everything, but the head of it was too small so it slid right through the hole.
DirTyPreTTyThinGs
Aug 15, 2007 08:35 PM
pane93civhb
Aug 7, 2004 08:51 AM
mz3bo
Aug 28, 2003 09:22 PM
BAZ
Jul 29, 2003 09:29 PM
