Help:Irrattic at 1000-2000 RPM
Old Aug 28, 2003 | 10:55 AM
DarkSol97's Avatar
Default Help:Irrattic at 1000-2000 RPM
In need of help. I have just recently swaped in a b16a2 into my 96 civic HB. The initial swap went without a hitch, although I was forced to use my original engine harness from my d16y7, and added in the necessary vtec wiring. Now, my question is when reving and while driving the engine at 1000 thru 2000 rpm, I begin starting to have this irrattic up and down reving. After passing 2000 rpm the car then drives normally. What could this porblem be...? Any info or diagnosis would be greatly appreciated!!!
Old Aug 28, 2003 | 12:30 PM
Aceman64's Avatar
Default Re: Help:Irrattic at 1000-2000 RPM (DarkSol97)
Any CEL? If so, what code(s)?
-Ace
Old Aug 28, 2003 | 12:36 PM
DarkSol97's Avatar
Default Re: Help:Irrattic at 1000-2000 RPM (Aceman64)
Forgot to mention a code 14 is given. Could that be the problem?
Old Aug 28, 2003 | 03:37 PM
DarkSol97's Avatar
bump
Old Aug 28, 2003 | 05:22 PM
user 9782082308's Avatar
Have you checked the plug for the IAC. Try taking the IAC off and spray it with carb cleaner followed by some wd40.
Old Aug 28, 2003 | 05:51 PM
Aceman64's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkSol97 &raquo;</TD></TR><TR><TD CLASS="quote">Forgot to mention a code 14 is given. Could that be the problem?</TD></TR></TABLE>
Theres your problem. Search for IACV and you will get alot of hits, I am beginning to think everyone has this problem..I know I do.
-Ace
Old Aug 29, 2003 | 03:12 PM
DarkSol97's Avatar
Reguarding the IAC valve. The D16y7 wire harness that Im using has a three wire plug and the IAC valve itself has only two prongs? Which wires go with which. The three wires on the harness are orange, black w/ blue stripe, and yellow w/ black stripe.
Old Sep 4, 2003 | 10:36 AM
DarkSol97's Avatar
I solved my IAC code problem, although Im still having this irrattic reving problem at 1000-2000 RPM. Anyone else have anymore suggestions?
Old Sep 4, 2003 | 11:05 AM
Aceman64's Avatar
So you arent getting the CEL 14, but still have the idle problem. Try adjusting the throttle cable, or the stop screw on your TB that sets the amount the butterfly can close.
-Ace
hondaon18's
10
Apr 8, 2011 04:35 PM
si_motor_spt
Oct 25, 2007 05:13 PM
i.
18
Oct 17, 2007 10:44 AM
ken-e
Dec 20, 2005 10:03 AM
socaly4life
Feb 2, 2005 05:24 PM
