Symptoms of a HOT running MOTOR B16....?!?!?
Old Aug 28, 2003 | 10:54 AM
ATS*VEEE's Avatar
Default Symptoms of a HOT running MOTOR B16....?!?!?
what are the symptoms of a hot running motor?!?! thermostat gauge is fine....never over heats....alwayz has coolant.....and would a hot motor effect power loss, performance, etc.....one more thing since im posting....symptoms of bad injectors?!?!?! or bad fuel pump, dirty, clogged,,,,etc......b16 ef hatchy still running like crap....15.7's......15.6's...
Old Aug 28, 2003 | 10:56 AM
SiB16A's Avatar
Default Re: Symptoms of a HOT running MOTOR B16....?!?!? (richierich)
Bad motor?.....maybe the motor has been beatin previously? did you do a compression check when you bought the motor? was it like over 185 all across all 4 cylinders?....hooking up to the ground? bad driving?
Old Aug 28, 2003 | 11:03 AM
mattb16a1civic's Avatar
i have a question along with compression why doesnt anyone ever try a cylinder leakage test. shows symptoms of bent vavles or bad valve seats, worn rings, bad head gasket, it could show so many things, and its not hard at all to do this test once u have the clt unit.
Old Aug 28, 2003 | 11:04 AM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richierich &raquo;</TD></TR><TR><TD CLASS="quote">what are the symptoms of a hot running motor?!?! thermostat gauge is fine....never over heats....alwayz has coolant.....and would a hot motor effect power loss, performance, etc.....one more thing since im posting....symptoms of bad injectors?!?!?! or bad fuel pump, dirty, clogged,,,,etc......b16 ef hatchy still running like crap....15.7's......15.6's...</TD></TR></TABLE>
You're motor is fine if your water temp is normal. As long as you're temp gauge is normal you have nothing to worry about. My b16 does the same thing; it runs really hot, but the temp gauge is normal. But I dont imagine that effecting your performance.
My b16 is hesitating too, but only under patrial throttle. I am sure it's clogged fuel injectors, but when i floor it it does not hesitate. Why don't you throw in a bottle of fuel system cleaner and see what happens. Good Luck
Old Aug 28, 2003 | 01:52 PM
ATS*VEEE's Avatar
compression yes 190 all across.....fuel injection cleaner...did that too...same thing........i have no clue....motor runs fine it seems to me....no bogg no check engine light....feels like its struggles when u floor it....like not getttin enoufh gas.....in 3rd gear it seems like the rpm's are taking forever to get up there
Old Aug 28, 2003 | 01:58 PM
Ef Whore's Avatar
Default Re: (richierich)
The #1 symptom of a hot running motor is a surging idle.....not sure if yours does, but try throwing in a 180 t-stat/waterwetter and see what happens.
Old Aug 28, 2003 | 02:11 PM
ATS*VEEE's Avatar
good looking out efwhore....it surges a lil bit....not a whole lot tho....it idles fine but sometimes its to low or to high....from normal range.....dont kno y it does it.....its wierd......
Old Aug 28, 2003 | 06:20 PM
ATS*VEEE's Avatar
ttt
Old Aug 28, 2003 | 06:34 PM
silverCRXTC's Avatar
also my b16a was hesitant at first but runs like a champ. AT first i only had a header intake and exhaust and stock b16a, it would throw o2 codes like whoa and hestiate, after a tune up this improved, but i felt a better response from changing the fpr to a b&m unit and adding 4 lbs of fuel, this was nice.. and improved its performance big time. (along with this aem fuel rail, skunk2 manifold and VFAC {holy ****! vfac rocks})
Old Aug 28, 2003 | 07:42 PM
riceboy's Avatar
Default Re: (silverCRXTC)
check the fuel filter?
Old Aug 28, 2003 | 07:46 PM
Jared's Avatar
Default Re: (riceboy)
Sounds normal. Stock B16s in ef hatches are weak. mid 15s on street tires all day. what are your 60' times.
Old Aug 28, 2003 | 08:11 PM
B16C's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">Sounds normal. Stock B16s in ef hatches are weak. mid 15s on street tires all day. what are your 60' times.</TD></TR></TABLE>
i can see that your car runs 11's, but come on now. b16's in ef's run high 14's, not mid 15's. how can a 2000 Si with the same motor and about 400lbs extra run 15.7 and the ef runs only 2 tenths faster? don't talk **** because your car is quick. speak the truth.
Old Aug 29, 2003 | 05:58 AM
TsunamiZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richierich &raquo;</TD></TR><TR><TD CLASS="quote">compression yes 190 all across.....fuel injection cleaner...did that too...same thing........i have no clue....motor runs fine it seems to me....no bogg no check engine light....feels like its struggles when u floor it....like not getttin enoufh gas.....in 3rd gear it seems like the rpm's are taking forever to get up there</TD></TR></TABLE>
are you using the stock fuel pump ......?
if you are , it could very well be the factory pump used for the sohc motor , cannot supply enough fuel for the higher fuel needs of the B16 ....you might want to upgrade , along with an FPR+ gauge ...
Old Aug 29, 2003 | 09:16 AM
ATS*VEEE's Avatar
still a stock fuel pump....but...ive seen other guys run stock sohc fuel pumps and they are fine....maybe mines just clogged? to old?!?!.....havent had any trouble with gas problems, starting car, cuttin out....etc.....boggin...
Old Aug 29, 2003 | 12:57 PM
TwoRedEGgs's Avatar
fuel filter, pump, clogged cat, plugs are gone...... if you've look at all those already then i'n not sure cause i think ppl have said almost everyting!!
good luck dude!
Old Aug 29, 2003 | 01:42 PM
ATS*VEEE's Avatar
new plugs, wires, cap, rotor, new cat and the old one was HELLA clogged, fuel filter.......basically everything except couple of things.........
Old Aug 29, 2003 | 04:48 PM
Jared's Avatar
Default Re: (B16C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C &raquo;</TD></TR><TR><TD CLASS="quote">
i can see that your car runs 11's, but come on now. b16's in ef's run high 14's, not mid 15's. how can a 2000 Si with the same motor and about 400lbs extra run 15.7 and the ef runs only 2 tenths faster? don't talk **** because your car is quick. speak the truth.</TD></TR></TABLE>
I'm not comparing it to my car, I'm just saying that it's not very strong in stock form. I've seen multiple b16 ef swaps around here and I've never seen one break into the 14s without slicks, given some of you guys may be closer to sea level than me, so that might be the diffrence, but I'm just going off what I've seen.
blackeg
Jan 20, 2009 03:56 PM
GdmLaz
Jan 28, 2008 04:54 PM
JustHere4ADay
Dec 10, 2007 08:15 AM
ATgrills.com
Feb 1, 2005 04:18 AM
handa
Aug 31, 2004 04:23 PM
