BAD compression!!!!! Need help
Old Jan 26, 2005 | 05:21 AM
ATgrills.com's Avatar
Default BAD compression!!!!! Need help
Ok my friend did a compression test on his C5 and its way off...
with plugs in he got, 165, 127, 135, 165
the motor runs fine, no problems whatsoever,,, however the motor is boosted, he is runing JRSC at 8PSI and the car pulls hard... dosent smoke or anything!
is this serious? what do you guys think the problem is? valve seal, head gasket?
thanks
Old Jan 26, 2005 | 06:06 AM
Bbasso's Avatar
Default Re: BAD compression!!!!! Need help (ATgrills.com)
Sounds like there might be a problem, I would re-check the #s with a different gauge.
Is there any internal work/ mod to the motor?
Old Jan 26, 2005 | 06:17 AM
RTW DC2R's Avatar
with the plugs in?
was this done with the motor warm and at WOT?
Old Jan 26, 2005 | 06:21 AM
DC2-JRSC'd's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">with the plugs in?
was this done with the motor warm and at WOT?</TD></TR></TABLE>
What he said plus add 2-3 drops of oil in each cylinder and re-check. if the numbers jump up you have bad rings.
how long has he been using the supercharger? 8 psi is a little much for a r without tuning. does he have stock injectors, ecu, fuel pump?
Old Jan 26, 2005 | 08:16 AM
Phoenix_ITR's Avatar
definitely re-check the numbers, as stated above.
a leakdown test probably wouldn't hurt either...
Old Jan 26, 2005 | 09:45 AM
Default Re: BAD compression!!!!! Need help (delinquent)
car is tuned with hondata and put down 240WHP...
so leak down test would be better right?
Old Jan 26, 2005 | 09:48 AM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com &raquo;</TD></TR><TR><TD CLASS="quote">
so leak down test would be better right?</TD></TR></TABLE>
yes....thats a good place to start right now! Somethings wrong if your #'s were that inconsistent.
Old Feb 1, 2005 | 04:18 AM
jdmjohnny's Avatar
Default Re: BAD compression!!!!! Need help (Jon D)
yea leak down would b better.also try a wet compression test..squirt some oil in each cylinder..
doublezerohatch
Jul 1, 2013 08:03 AM
GdmLaz
Jan 28, 2008 04:54 PM
Minglor
Jul 30, 2006 05:09 PM
pip9
Aug 24, 2004 04:02 PM
H23ludedude
Oct 21, 2002 10:41 PM
