Any Ever Tried This??? Is it Worth it
Old Aug 27, 2003 | 10:03 AM
96 Ls lnTeG's Avatar
Default Any Ever Tried This??? Is it Worth it
I say this on Ebay you think it worth it cause i seen one's Autozone... like 130.00 well http://cgi.ebay.com/ebaymotors...43998
Old Aug 27, 2003 | 10:47 AM
EE_Chris's Avatar
Default Re: Any Ever Tried This??? Is it Worth it (96 Ls lnTeG)
I'd say its not worth it, especially if all it does is spit out a code. You can jump the service connector and get the blink code instead for free.
Old Aug 27, 2003 | 10:49 AM
obd2gsr's Avatar
what's wrong with a paperclip and reading the blinking check engine light?
Old Aug 27, 2003 | 05:15 PM
civic-4-ges's Avatar
Default Re: Any Ever Tried This??? Is it Worth it (obd2gsr)
The only advantage is that the code checker will give you more descript p codes, which could help determine the problem more then the MIL indicator
Old Aug 27, 2003 | 05:37 PM
sackdz's Avatar
Default Re: Any Ever Tried This??? Is it Worth it (civic-4-ges)
There are far more capable units, that will not only pull trouble codes and let you reset them, but also display real time sensor readings.
Old Aug 27, 2003 | 08:35 PM
blah13's Avatar
Default Re: Any Ever Tried This??? Is it Worth it (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">There are far more capable units, that will not only pull trouble codes and let you reset them, but also display real time sensor readings.</TD></TR></TABLE>
I'm assuming that = $$$ but I'm curious to know more, any name brands etc I could look up on?
Old Aug 27, 2003 | 09:22 PM
tominos's Avatar
Default Re: Any Ever Tried This??? Is it Worth it (blah13)
snap on
my shop teacher has a snap on handheld computer, plugged it in and it gave out all the readings from the ecu. pretty tight. but it cost about $5,000. so, guess i'll have to live without it.
Old Aug 28, 2003 | 06:28 AM
Default Re: Any Ever Tried This??? Is it Worth it (tominos)
http://www.auterraweb.com
Old Aug 28, 2003 | 06:55 AM
T4eg's Avatar
yea the snap on scanners are awesome. We have them and the scopes. Between the two of them you can figure out anything
Old Sep 11, 2003 | 07:10 PM
Default Re: Any Ever Tried This??? Is it Worth it (BlueHatch00)
99 Dollars at Schucks
http://www.partsamerica.com/Pa...=3389
Old Sep 12, 2003 | 08:07 AM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd2gsr &raquo;</TD></TR><TR><TD CLASS="quote">what's wrong with a paperclip and reading the blinking check engine light? </TD></TR></TABLE>
kidcruze
Jul 18, 2008 01:45 PM
drumminforev
25
Nov 11, 2006 09:19 PM
211811518
10
Sep 9, 2006 12:57 PM
PINKS
11
Jul 13, 2006 06:00 PM
billyhoe
Oct 17, 2004 08:58 AM
