wiring help!!!
Old Aug 27, 2003 | 08:05 AM
Doc Brown's Avatar
Default wiring help!!!
i had an internal coil obd 2 dizzy converted to obd 1. but the wireing harness is made for the external coil. the car only runs when the external coil is pluged into the wiring harness. i think it is compleating the circuit. but the coil wire is not hooked up due to the internal coil on the dizzy. is there any way to fix this problem. i want to get rid of the external coil all together. and also my tachs do not work anymore. any ideas.
Old Aug 28, 2003 | 03:48 AM
Doc Brown's Avatar
i need help ASAP!!! anyone, please
Old Aug 28, 2003 | 05:16 AM
JimBlake's Avatar
Default Re: (Doc Brown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doc Brown &raquo;</TD></TR><TR><TD CLASS="quote">i need help ASAP!!! anyone, please</TD></TR></TABLE>It's kinda hard to help you - I don't know what kind of car you have, which distributors, some kind of customized wiring harness?? Circuit diagrams are what you need, check out what circuit has that external coil in it? Trace wires & find out...
Old Aug 28, 2003 | 05:51 AM
T4eg's Avatar
Default Re: (JimBlake)
are you still using the OBD2 harness? If so remove the OBD1 harness from the distributor and change it out with the OBD2 connector.
Old Aug 28, 2003 | 06:00 AM
Ovrbst_T66's Avatar
Default Re: wiring help!!! (Doc Brown)
what color are the wires going to the external coil? you have to jump the wire at the clip to complete a circuit.i had the same prob with my h22.
Old Aug 28, 2003 | 07:55 AM
Doc Brown's Avatar
i am not for shure what color they are. i at work and the car is not with me. i know one is yellow and there are 3 wires. but i will try doing what you did. thanx for the help. i will let you know what happends.
Oh any idea why my tachs do not work anymore? can i just put the tach wire on the postive side of the coil? it is internal
Old Aug 28, 2003 | 10:38 AM
Doc Brown's Avatar
3 wires, yellow, black with yellow stripe, and blue.
Old Aug 29, 2003 | 09:10 AM
Doc Brown's Avatar
hey danny t66 where you at. i need your help ASAP! i would greatly appreceite it !!
Old Aug 29, 2003 | 04:53 PM
Ovrbst_T66's Avatar
sorry i could'nt get back to you sooner jump the blk/yel to the yellow that should be it.
Old Aug 29, 2003 | 07:50 PM
Doc Brown's Avatar
hey thanx alot. it work. now i just need to get my tachs to work
Old Aug 30, 2003 | 04:36 AM
Ovrbst_T66's Avatar
try the blue wire for your tack signal that might work. or at the distributer there is a two wire plug the blue is the tack signal.
Old Aug 30, 2003 | 07:59 AM
Doc Brown's Avatar
well that is what i thought, but ihad my dizzy converted from obd 2 to obd 1, so there is not teck wire from that. well no blue wire at least. well i know there has to be a nother wire that i can tap into. my vafc still show rpm's but i hate looking at the small *** screen. i like my moster tack.
Old Aug 31, 2003 | 09:00 AM
Ovrbst_T66's Avatar
connect your tack to the blue wire at the distibuter,its a two wire plug one wire is blk/yel and the othe is blue (rpm signal).
Ben Martin
May 2, 2016 05:13 PM
JDMboostedB16
Sep 13, 2004 07:58 AM
