Silly question...? Turbo + brake booster
Old Aug 26, 2003 | 11:23 AM
raene's Avatar
Default Silly question...? Turbo + brake booster
This might be a silly question, but something just struck me...
The brake booster operates off vacuum in the intake manifold. But how does the booster function when there's a turbo pushing boost into the manifold? Does it operate off residual vacuum using its 1-way valve?
TIA
Old Aug 26, 2003 | 11:53 AM
Kataku2K3's Avatar
Default Re: Silly question...? Turbo + brake booster (raene)
Most of the time your brake when you're not in boost meaning you have a negative manifold pressure (vacuum)... I've never tried BRAKING while in boost so I really don't know... I'm sure you could slow down but it would be like braking when the car manifold has zero vacuum (at rest)...
Old Aug 26, 2003 | 01:50 PM
raene's Avatar
Default Re: Silly question...? Turbo + brake booster (Kataku2K3)
That's what I thought, thanks
I figured it would be a problem for, say, autoXers who do a lot of brake + throttle to help the car rotate
Old Aug 26, 2003 | 02:58 PM
7PSI CRX's Avatar
Notice the check valve.
(#5)
Boost pressure never sees the boosters’ diaphragm.
With the engine off, you still have "power assist" for about 4-6 brake applications.
Old Aug 26, 2003 | 03:05 PM
GZERO's Avatar
Default Re: Silly question...? Turbo + brake booster (7PSI CRX)
yeah, besides, you're not always in boost for more than a certain time, but yes, the check valve saves the day.
Old Aug 26, 2003 | 03:54 PM
raene's Avatar
OK that makes sense
Next question then is, how strong is the check valve? The PCV has a check valve that gives out on mild boost, right? What psi will the brake booster check valve give out on, roughly? Or are they even comparable?
Freshdot
Jun 18, 2010 06:34 PM
sinister357
Aug 31, 2007 06:32 AM
egcoupeautox
Oct 16, 2005 06:23 PM
99teggsr
Jun 1, 2005 09:39 PM
Lei Siew Long
Apr 23, 2003 10:45 AM
