forces induction and braking
Old Aug 30, 2007 | 09:40 AM
sinister357's Avatar
Default forces induction and braking
with positive pressure in the intake manifold, won't it be harder to press on the brake pedal without the vacumn assist?
Old Aug 30, 2007 | 09:44 AM
SOHC_MShue's Avatar
Default Re: forces induction and braking (sinister357)
are you going to be breaking while you are in boost?
Old Aug 30, 2007 | 09:48 AM
Default Re: forces induction and braking (SOHC_MShue)
no but i'm just say without the vacumn, woulnd't it be harder to press the brake pedal. for those of you who are turboed, how is the braking?
Old Aug 30, 2007 | 10:04 AM
sneakysneaky's Avatar
nope, my car brakes just fine.
Old Aug 30, 2007 | 10:10 AM
morgan@synapse motorsport's Avatar
if you have your pedal on the gas and the brake at the same time....
Old Aug 30, 2007 | 10:58 AM
SOHCD16y8's Avatar
Check Valve doesnt allow boost to pressurize the booster, therefore it is no more difficult then a stock motor while hitting zero vacuum and hitting the brake.
Old Aug 30, 2007 | 11:23 AM
Default Re: (SOHCD16y8)
i unplugged the vacumn for the booster and the brakes are hard as hell.
Old Aug 30, 2007 | 11:25 AM
no surprise there.
Old Aug 30, 2007 | 11:48 AM
adseguy's Avatar
Default Re: (mike@synapse motorsport)
I still don't see how you are confused about this. What situation arises that you need brakes AND WOT at the same time?
Old Aug 30, 2007 | 11:53 AM
Default Re: (adseguy)
i think i get it now. when you're not on the gas, you get negative pressure back in the intake manifold. is that right?
Old Aug 30, 2007 | 12:01 PM
TehGhett0P1mp's Avatar
Unless you are in boost I think it will be normal as far as breaking goes, im not sure 100% but that is what I have gathered from what has been said here so far.
Old Aug 30, 2007 | 12:06 PM
Boilermaker1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">I still don't see how you are confused about this. What situation arises that you need brakes AND WOT at the same time?</TD></TR></TABLE>
Race track or autocross.... left foot braking.
Old Aug 30, 2007 | 12:09 PM
sp00led's Avatar
Brake boosting
Works like a champ for hwy racing.
Old Aug 30, 2007 | 01:02 PM
adseguy's Avatar
Default Re: (sp00led)
Race track/autocross and brake boosting don't pump the brakes enough or don't go to WOT hard enough respectively that boosting and braking would be a problem. So I guess I have to clarify sorry
Old Aug 30, 2007 | 01:11 PM
Schister66's Avatar
Man U FTW
wasn't there just a thread on this like a day ago?
Old Aug 30, 2007 | 01:53 PM
PHDZINE's Avatar
Default Re: (rota92)
He wants to do a power brake burn out like the RWD. Full throttle and on the brakes.
Old Aug 30, 2007 | 06:59 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">are you going to be breaking while you are in boost? </TD></TR></TABLE>
while brake boosting on the highway lol. gotta get the jump
Old Aug 30, 2007 | 08:08 PM
2point2's Avatar
Default Re: (sinister357)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister357 &raquo;</TD></TR><TR><TD CLASS="quote">i think i get it now. when you're not on the gas, you get negative pressure back in the intake manifold. is that right? </TD></TR></TABLE>
yes... sort of.
When you are not in boost you suck the air out of the brake booster. The brake booster is like a holding tank with negative pressure - the check valve quickly closes as soon as the booster starts to de-pressurize, keeping the brake booster de-pressurized.
Old Aug 30, 2007 | 08:53 PM
rmcdaniels's Avatar
Default Re: (2point2)
Assuming you are using your right foot for braking, as soon as you take your foot off the gas the throttle plate closes, creating vacuum in the intake manifold.
i.e. - There will be no difference in braking.
Old Aug 31, 2007 | 06:32 AM
boostedcivicsir's Avatar
Mr. Badwrench
only a car with an auto trans that has no check valve in the line while up on the converter. we didnt have this issue in the t type, we had hydraulic assisted brakes.
Andrew Vang
Apr 30, 2019 04:36 AM
nickstick33
Sep 14, 2012 04:43 AM
whited
Aug 6, 2012 12:18 PM
Eighty-Nyne
12
Apr 28, 2009 07:59 PM
pineapplemike
Nov 23, 2005 07:25 PM
