just did a Compression Test on my B16a, opinions wanted???
the reason i did a compression test was because of my weak dyno numbers;
139HP
100TQ
w/ JDM 2nd gen B16a I/H/E, ITR manifold, CTR Cams, and FPR
Starting from the distributor to the motor mount;
205, 200, 195, 200
Then added a cap-full of motor oil;
230, 215, 235, 200 <-----not too accurate because the battery kinda give away, but the other 3 cylinders had good cranks
from the numbers above it leads me to believe that my piston rings are fucked, any opinions on what else could cause my motor to be such a bitch????
original post: https://honda-tech.com/zerothread?id=596077
139HP
100TQ
205, 200, 195, 200
okay so at least i meet average compression, but then where did all my power go??? On my original post, i posted why is my B16 so weak and found out that everyone with my exact or near exact mods are making 20-30HP more than me and thats some ****
i dont think its my fuel because im running a B series pump and i just changed the fuel filter and put in a the bigger SI fuel hose as well, but igition is a whole other story. Should i start with wires then cap and rotor then move into ignitor and coil
it could be that ITR manifold.... i hear rumors that a mild b16 wont make any power with it.... it made more power with the stock mani....(clubsi\NA forum guys know more of this)....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST »</TD></TR><TR><TD CLASS="quote">it could be that ITR manifold.... i hear rumors that a mild b16 wont make any power with it.... it made more power with the stock mani....(clubsi\NA forum guys know more of this)....
i dont know about that one, others were making 160-170HP with the exact same setup and thats where i thought i would be, but when i dynoed it that wasnt the case
could a bent vavle cause such a power loss??? i remember when i first got the motor and ran a chipped P28 that had a rev limit of 8600 RPM, i went vtec happy on that sucker. just a thought because i havent reved it that high since when i just got the motor
celestialcivic91
Jan 23, 2007 03:12 PM
y_design
Jul 13, 2004 12:39 PM
