wat to do with 98+ civic air box sensor on boost application?>
imma turbo my buddies 98 civic CX, but first i wantt to find out twhat to do with the air box sensor? do i leave it or make a bung for it and filtration sysytetm for tthe turbo ? thanks. also post up your D16Y7 set tups !! and p ics would be greatt, thaanks. sorry for tee spelling. my keyboard is kinda broken.
how do y ou make sure it stays in there ? instead of pops ouot and leaks boost ? in te chharge pipe or should i lengthen the wire n' make an intake :?
I drilled a hole in the GReddy piping, basically where the sensor sat in the stock intake. Just used a peice of rubber hose as a sleeve over the base of the sensor and wedged it into the pipe. Nice snug fit, never popped out.
Your talking about that little air temp sensor right? You "plug" the sensor into a rubber hose and run the hose to a bung on the air intake into the turbo. The Greddy kit for example comes with the hose and a bung ready to go.
HTH
Mark
HTH
Mark
