wat to do with 98+ civic air box sensor on boost application?>
Old Aug 25, 2003 | 09:24 PM
project dc2's Avatar
Default wat to do with 98+ civic air box sensor on boost application?>
imma turbo my buddies 98 civic CX, but first i wantt to find out twhat to do with the air box sensor? do i leave it or make a bung for it and filtration sysytetm for tthe turbo ? thanks. also post up your D16Y7 set tups !! and p ics would be greatt, thaanks. sorry for tee spelling. my keyboard is kinda broken.
Old Aug 25, 2003 | 09:29 PM
paulzy's Avatar
Default Re: wat to do with 98+ civic air box sensor on boost application?> (project dc2)
tap it into the piping or manifold
edit:spelling
Old Aug 25, 2003 | 09:36 PM
mrod006's Avatar
Default Re: wat to do with 98+ civic air box sensor on boost application?> (Paul_Vang)
make a bung on the intake manifold piping. that's what i did to my greddy kit.
Old Sep 2, 2003 | 11:43 PM
Default Re: wat to do with 98+ civic air box sensor on boost application?> (mrod006)
how do y ou make sure it stays in there ? instead of pops ouot and leaks boost ? in te chharge pipe or should i lengthen the wire n' make an intake :?
Old Sep 3, 2003 | 06:57 AM
VTC_CiViC's Avatar
I drilled a hole in the GReddy piping, basically where the sensor sat in the stock intake. Just used a peice of rubber hose as a sleeve over the base of the sensor and wedged it into the pipe. Nice snug fit, never popped out.
Old Sep 3, 2003 | 07:16 AM
01ITR#700's Avatar
Default Re: wat to do with 98+ civic air box sensor on boost application?> (VTC_CiViC)
Your talking about that little air temp sensor right? You "plug" the sensor into a rubber hose and run the hose to a bung on the air intake into the turbo. The Greddy kit for example comes with the hose and a bung ready to go.
HTH
Mark
pjr710
Apr 3, 2009 08:25 AM
zach1288
Aug 11, 2008 08:42 PM
b16 matt
Mar 28, 2003 02:40 PM
wanabecivicex
Nov 6, 2002 02:54 AM
