All motor LS B16 pistons and 2 layer head gasket..... gains??
Old Aug 25, 2003 | 07:11 PM
Dan GSR's Avatar
Default All motor LS B16 pistons and 2 layer head gasket..... gains??
I have extra B20 rods laying around (same as LS )
I also have extra B16 pistons
I plan on going LS/VTEC in the future....next year some time.
But in the mean time I was considering the following
shot peen the B20 rods
arp rod bolts
B16 pistons
new rings
new bearings
2 layer head gasket
should net me a considerably higher compression ratio than stock
11:1 using C-speedracing calculator
another advantage of doing this now would be that I could break in the rings now. so that once I put the vtec head on....I can go beat on it right away....instead of having to break in the new rings if i did it all at once
now the question is?
will it net me gains? if so how much?
keep in mind all I have is a CAI and cat back.
so this would be with stock ECU and stock exhaust manifold
and would it be safe with stock ECU
I plan to use hondata s200 once i go LS/VTEC
Old Aug 25, 2003 | 08:37 PM
chameleon's Avatar
Default Re: All motor LS B16 pistons and 2 layer head gasket..... gains?? (Dan GSR)
poor man's lsvtec ?
Old May 6, 2004 | 01:43 PM
Lshatchy91's Avatar
Default Re: All motor LS B16 pistons and 2 layer head gasket..... gains?? (chameleon)
Bump... cause i want to know tooooo!!
Old May 6, 2004 | 04:08 PM
89s1's Avatar
Default Re: All motor LS B16 pistons and 2 layer head gasket..... gains?? (Lshatchy91)
if you're worried the ecu will dump on it then I would sugggest all the same mods minus the 2layer HG, just use an OEM one and you'll be laughin.
the stock ecu has no problem with that at all.
LS/VtecCrew1
Mar 29, 2009 12:27 PM
LSVtechnologytur...
Feb 28, 2008 11:37 PM
HondaBurger
Sep 19, 2007 02:36 PM
2004cobra
Dec 27, 2006 11:55 PM
DLB1994
May 15, 2002 11:42 AM
