vtec problem
Old Aug 24, 2003 | 08:18 PM
skimb37's Avatar
Default vtec problem
half the time i go into vtec i hav a cel go on and it is p1258
Old Aug 24, 2003 | 08:36 PM
VTECorona's Avatar
Default Re: vtec problem (skimb37)
Check your code again, that's not a valid one.
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
65 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
Old Aug 26, 2003 | 03:04 PM
civic-4-ges's Avatar
Default Re: vtec problem (VTECorona)
I agree, not a valid code, re-check and compare to this
http://pub161.ezboard.com/fbse...topic
Old Aug 26, 2003 | 03:32 PM
skimb37's Avatar
Default Re: vtec problem (civic-4-ges)
sorry. p1259 vtec system circut bank 1 ny auot xray said
Old Aug 26, 2003 | 04:11 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skimb37 &raquo;</TD></TR><TR><TD CLASS="quote">sorry. p1259 vtec system circut bank 1 ny auot xray said</TD></TR></TABLE>
what?
14baldo66
May 3, 2021 05:50 PM
lblingldawg
Apr 27, 2006 03:10 PM
Downz
Apr 24, 2006 08:55 AM
Del Sol on Steroids
Dec 1, 2005 07:56 PM
2dark2bslow
Jun 2, 2004 06:33 PM
