How much oil with turbo?
Old Aug 24, 2003 | 06:26 PM
Pfieff's Avatar
Default How much oil with turbo?
I just got done with a turbo install on my '00 civic and I know standard oil changes, I put in 3.8 quarts, which is the recommended amount. I was just wondering how much more, if any, do I add now that there is a turbo. Thanks,
Pfieff
Old Aug 24, 2003 | 07:32 PM
bumpin_bass's Avatar
Default Re: How much oil with turbo? (Pfieffdog)
Revhard says put in 4.5 quarts.
Old Aug 25, 2003 | 11:22 AM
Pfieff's Avatar
thanks, i imagine it has to be close for the greddy kit
Old Aug 25, 2003 | 12:14 PM
Goldfingiz's Avatar
Default Re: (Pfieffdog)
I put 4.5 in my boosted b20.
Old Aug 25, 2003 | 01:00 PM
TRE_'s Avatar
Default Re: (Goldfingiz)
i usually put about 4.35-4.5 quarts in.
Old Aug 26, 2003 | 05:54 PM
B_1_8_hatch's Avatar
what about 5qts of oil boosting an ls motor?
what about weight of the oil, whats a good weight to use?
Old Aug 26, 2003 | 06:11 PM
Double121's Avatar
Put in about 4qts to start with, then run the car a minute and cut it off. let it set 10min. and check the level. Add till its at the top dot on the stick and keep it there. I check my oil everyday. I generally burn a qt of oil between changes.
navymike321
Aug 9, 2010 08:29 PM
Cee_mon
Nov 18, 2005 06:11 AM
RACEPAK
May 25, 2004 09:07 AM
71 mgb
Nov 12, 2003 10:49 AM
92JDMSiR
Apr 22, 2002 10:25 PM
