can Greddy E-Manage be re-wired for 96-00 civics like the blue box?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I found this on ebay, because I need fuel management for a used greddy kit:
http://cgi.ebay.com/ebaymotors...18541
Can it be re-wired for a 96-98 civic with the turbocivic.net instructions, just like the blue box can? is the pre-programmed unit better than the blue box?
kinda OT for youre question...but why is the guy calling it an FMU but showing an eManage?
it looks like it has the injection and ignition harnesses on it. dirt cheap price if its a legit deal i think.
Re: can Greddy E-Manage be re-wired for 96-00 civics like the blue box? (fnananon)
the emanage is not preprogrammed if it didn't come with any kit. it's a universal unit like the SAFC/VAFC. You need all the harnesses inorder to access all the features from the unit. the E-01 is definately a perfect item to use in conjunction with the Emanage, since the need for a laptop computer is not necessecary once you plug the E-01 into the Emanage. All adjustments can be done to the Emanage from the E-01 montior and controller. You need the software to install the program onto your laptop if you want to do any adjustments, that's why the EBAYer couldn't adjust anything....probably. Compatability doesn't seem right, since its a universal unit. Otherwise the E-01 is perfect solution since it works as a boost controller/laptop alternative, and has the program already installed into it
Re: can Greddy E-Manage be re-wired for 96-00 civics like the blue box? (mamaboy)
no it came with his turbo kit, but he assumed that it wouldn't work for his setup because he has a 2000 civic. However, maybe he hasn't seen the diagrams on http://www.turbocivic.net , as they tell how to properly wire it for a 96-00 civic. Anyone have input on this?
turbod16y7vtec
12-12-2002 08:48 AM
