more temp gauge problems
Old Aug 23, 2003 | 10:40 PM
1slowaccord's Avatar
Default more temp gauge problems
I posted a thread last week about my temp gauge not working. A lot of people responded and recomended that I change my sending unit. I finally got around to it today and was disapointed to see that my temp gauge still doesn't work. Does anybody have any other ideas of what it might be????
Old Aug 24, 2003 | 12:54 PM
Default Re: more temp gauge problems (Spliff101)
ttt
Old Aug 24, 2003 | 06:55 PM
4DRPIMPIN's Avatar
what exactly is the problem. not working at all or not accurate..?
Old Aug 24, 2003 | 07:38 PM
jspark79's Avatar
what are you talking about changing the sending unit bro???
did you try changing the radiator cap?
or
did you think of changing the particular gage from the cluster?
Old Aug 24, 2003 | 10:46 PM
Starrman85's Avatar
Default Re: more temp gauge problems (jspark79)
you install any indiglo gauges lately? you mighta broke the needle.
as for sending unit, i dunno bout that, maybe a bad thermostat tho. look into that.
Old Aug 27, 2003 | 04:38 PM
Default Re: more temp gauge problems (STARRMAN85)
The gauge doesn't work at all. The thermostat was changed not too long ago. I have heard that it might be the gauge itsself, but how do i get to it to change it? Is it easy or do I have to tear a bunch of things out to get to it? It seems that everybody was confident about the sending unit until it failed. I'd like to get this problem fixed fast cause I'm gonna be driving back from vegas in a few days in the middle of the day and i don't want to burn anything up. As for the radiator cap, what will that do? Will that help my gauge problem or was it just some fun suggestion? Help me out folks.
Old Aug 28, 2003 | 05:01 AM
JimBlake's Avatar
I don't know what car you have, but maybe this is about the same for all...
Unplug the sender, ground the wire. Turn on the ignition & watch the temperature needle climb. MAKE SURE YOU TURN IT OFF BEFORE IT GETS ALL THE WAY UP. If you let it go all the way up you can fry the gauge. If this doesn't work, you can take out the cluster & check the wiring. Got an electrical diagram for that?
My Helm books have the resistance of the sender at different temperatures. The way to check the sender is to put it in a pot of hot water along with a thermometer, and measure it's resistance.
Old Aug 28, 2003 | 09:31 PM
Default Re: more temp gauge problems (JimBlake)
How do I take out the gauge cluster? I'll try the sender thing but i just replaced the unit and i'm not sure if that is it. The thermostat was also changed recently. By the way its a 95 Accord LX.
NAmodified
Apr 3, 2007 02:08 PM
crucial-vtec
Oct 28, 2005 11:42 AM
robtackett
Oct 21, 2005 07:35 PM
jpnucrx
Oct 14, 2005 02:24 PM
Boofster
Dec 6, 2004 03:18 PM
