missing v-tec
Old Aug 14, 2001 | 08:42 PM
D16Z6racing's Avatar
Default missing v-tec
i just bolted in an si (d16) in my 93 civic hb. d16 motor, si ecu, si harness, si everything...., but I'm not getting v-tec at all. and my check engine light stays on. i heard that if your check engine light is on, your ecu goes to a safety mode and won't let v-tec kick in. is that true? if anyone knows what could be wrong please let me know. thanks.
Old Aug 14, 2001 | 09:34 PM
4doorH22's Avatar
Default Re: missing v-tec (buster13)
VTEC still engages with the check engine light on. You need to read the codes dude. Any other abnormalities beside the CHL and no VTEC?
Edit: Oops, CHL should be CEL=check engine light
[Modified by H22power, 1:35 AM 8/15/2001]
Old Aug 14, 2001 | 10:18 PM
haloseven's Avatar
kickass kill
Old Aug 14, 2001 | 11:57 PM
liam821's Avatar
25 Year Member
Default Re: missing v-tec (H22power)
Incorrect. VTEC will not engage with the CEL on. With the CEL on, the engine goes into limp mode. It uses a static (rich) fuel map, no vtec, and changes a bunch of other things..
You need to check the codes. Its easy to do....take a paper clip and jumper the ECU plug..its green and is under the glove box. There should be two plugs under there...you want the one with only two prongs...not three. Stick the paper clip into each side and turn on the ignition to "ON".
Watch that check engine light..it will flast a code.
LONG flashes are the first digit, shorter flashes are the 2nd number..
so "FFFFFLLLLLLLAAAASSSSSH FFFFFLLLLAAAASSSSSSHHHH flash flash flash" is code 23.
there will be a long pause between the flashes...then display the next error code. It will repeate.
Here is a link to what the codes mean..
http://ecutecparts.com/ccodes/honda.html
good luck...
liam
Old Aug 15, 2001 | 04:25 AM
taZman's Avatar
New User
Default Re: missing v-tec (liam821)
Great Kill Dude
Old Aug 15, 2001 | 05:43 AM
JG Luder's Avatar
He knows that THIS is the place that you go for info... **** the fact that it isn't a kill....
#1. check to make sure the VTEC solonoid is plugged in tight.
#2. check to make sure the oil pressure is high enough.
start there, and call us back.
Old Aug 15, 2001 | 05:47 AM
redline's Avatar
Default Re: missing v-tec (JG Luder)
Depands on the code vtec might work.
dude is there oil in the engne?
Old Aug 15, 2001 | 05:50 AM
4doorH22's Avatar
Default Re: missing v-tec (redline)
Yeah, yeah, VTEC still works; depends on the code.
Old Aug 15, 2001 | 06:01 AM
Drew M's Avatar
New User
Maybe it is kicking in and you just don't notice it because it is a turd? It isn't like VTEC feels like a turbo spooling up or anything.
Old Aug 15, 2001 | 07:01 AM
4doorH22's Avatar
Default Re: missing v-tec (Cobra)
Be quiet pushrod boy.
Old Aug 15, 2001 | 08:55 AM
B18C-EJ1
Guest
Posts: n/a
What are you doing here? This is a Honda forum.
Don't you belong on a FudBoard?
bmxmacdaddy
Feb 28, 2009 01:49 PM
813tampa
13
Mar 17, 2008 10:47 AM
wicked_b16eg
Jan 8, 2008 11:01 AM
si90rex
Jul 5, 2006 03:12 PM
springfieldcivic
15
Jun 24, 2005 02:26 PM
