PLEASE HELP integra cluster in my eg isnt working properly
Old Aug 23, 2003 | 09:23 PM
TuCKiNaLL4s's Avatar
Default PLEASE HELP integra cluster in my eg isnt working properly
ok ive read about 5 posts in forums and even did research on the net i have everything connected right i even checked how my friend has it in his hatch and i have it wired the same way only problem is that when i turn on the car the rpms and the tachometer work but the temparature goes str8 to H and the fuel gauge stays on EMPTY and i have double checked even checked it over like 10 times now its connected correct could anyone have an idea why its doing that my cluster is a 92-97 jdm type r cluster thanks...any helkp will be appreciated alot maybe i can even breAK YOU OFF A COUPLE BUCKS THRU PAY PAL IF U HELP ME thanks, Orlando
Old Aug 24, 2003 | 05:43 AM
Default Re: PLEASE HELP integra cluster in my eg isnt working properly (TuCKiNaLL4s)
some1?
Old Aug 24, 2003 | 06:32 AM
TurboBumblBee's Avatar
i think you may have the two wires reversed.. different year guage clusters had different lights on it for example abs, srs, and seat belts.. they were in different possitions on the cluster therefore different wire may be used.. sounds lik eyou got the gas and temp wires mixed, how full is your gas tank? and ahve you checked all the fuses under the dash and hood???
Old Aug 24, 2003 | 06:35 AM
Default Re: PLEASE HELP integra cluster in my eg isnt working properly (Hybrid95CivicEX)
pmed ya
Old Aug 31, 2003 | 09:29 PM
ok i finally got it if anyone needs help on the wiring pm me or email me and ill send you the diagram i have everything works fine on my cluster now i have a 97 JDM type r cluster in my 93 cx hatch
Old Aug 31, 2003 | 09:32 PM
EARLdaSQUIRREL's Avatar
official honda whore
sounds good... i had a cpl glitches with my cluster but after lookin at the back and searching around got it all figured out... its a shame i dont have the car i did all the work to anymore
boostedNOTHARDLY
15
Jul 27, 2010 06:03 PM
JDM_WHR
10
Jun 7, 2010 08:50 AM
opiumdaze
Apr 10, 2005 05:24 PM
JDM*BUBBLE
Mar 29, 2004 04:48 PM
st0nedstoopid
Jan 20, 2004 05:26 PM
