Gauge cluster stoped Working
Old Jan 20, 2004 | 02:02 PM
st0nedstoopid's Avatar
Default Gauge cluster stoped Working
i was remounting a GSR cluster in my 98 civic .. and back uped .. went down the street then Speedo.. tach.. ect just stoped working.. I turned the car on the checked the voltage on them and there getting voltage through them so woudl anyone know if any fueses or what wire would take out the cluster.. mind that the battery icon does show up when ing. turned on.
Old Jan 20, 2004 | 02:24 PM
whatVTEC's Avatar
Default Re: Gauge cluster stoped Working (st0nedstoopid)
sorry to steal you thread, but I have a similar problem too if anyone can help. I gotta EG and my dash lights don't work sometimes. Not just the cluster the whole dash (cluster, defroster switch, illum switch, heater controls...etc)
Old Jan 20, 2004 | 02:42 PM
sm00thk0zz's Avatar
Default Re: Gauge cluster stoped Working (whatVTEC)
It sounds like you have a loose connection. My friend is having the same problem on his prelude. He can kick the wiring harness under his dash and EVERYTHING stops working, he can kick it a few more times and it will come back on. We have been to lazy to try and figure out what is not connected good though.
Old Jan 20, 2004 | 02:50 PM
Default Re: Gauge cluster stoped Working (sm00thk0zz)
i dont belive its a loose connection cause i checked and each connetion is getting voltage when started up .. so i was wodnering what fuses would go with the cluster
Old Jan 20, 2004 | 04:40 PM
Kendall's Avatar
My cluster went out in my ITR, I can't remember which fuse it was, but your problem doesn't sound like a blown fuse if the batttery light is working, pull the gauge cluster and make sure all the connections are good.
Old Jan 20, 2004 | 05:26 PM
Default Re: (Kendall)
Then which wire would make all that go out?
carlmel
Honda Civic (2001 - 2005)
May 11, 2026 08:57 AM
honda_boy23
Apr 6, 2011 11:47 PM
jdmeg6hatchy
14
Apr 22, 2009 06:24 PM
ge_ej1
Jan 31, 2008 09:00 AM
Ryan.
Oct 30, 2007 06:46 AM
