To those people running an MSD setup... SIMPLE questions...
I'll make this simple: can you run JUST a modified distributor cap and blaster 2 coil? Or do you NEED a ignition module(SCI, 6a, etc)? Would just running the coil be helpful?
Thanks
Thanks
i always asked my self the same question,,, but think about it like this,,, you have to remove the factory coil and run the rpm signal and power (or something) to the msd box, so i would say you prob have to use the msd box, thats my guess,, but im not completely sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch »</TD></TR><TR><TD CLASS="quote">you can run just the coil and cap..hell Iam doing it right now till my 6a comes in.</TD></TR></TABLE>
How did you hook up the coil? as in what wires did you run to it from where?
take the stock coil out..take the 2 wires that went to the coil..add a few feet of wire to them (cut off ends and solder the new wire on) notch the cap a little bit so wires can run thru..put cap back on..run wires to the coil..connect..run coil wire to the cap..start car and enjoy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin »</TD></TR><TR><TD CLASS="quote">thanks.
word.
thanks for your help.
</TD></TR></TABLE>word.
