Hondata + what else?
Hi,
I am looking into the Hondata s100 for my 99-00 Civic Si boosted at 7 psi. My goal is reliability, being a daily driver. What else do I need to get along with the Hondata? What size injectors? I am not looking to go past 10psi of boost. Do I need some sort of resistor box? Thanks
If you plan on getting injectors, RC actually makes 550cc injectors that are saturated, so you won't need the resistor box.
You can also buy Nippon Denso injctors that are 550cc that are saturated as well.
Both injectors are great, I personally have Denso's on my 99 Si.
If you have anymore questions, feel free to IM me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiLOtaku »</TD></TR><TR><TD CLASS="quote">If you plan on getting injectors, RC actually makes 550cc injectors that are saturated, so you won't need the resistor box.
Also you are gonna need to convert to OBD-1. Most common ECU to run is a P-28 found in the older Ex civics (92-95). You will also need a OBD-2 to OBD-1 wiring harness as well. Hope that helps
If you have anymore questions, feel free to IM me.</TD></TR></TABLE>
doh!,
forgot about the harness and ECU part, my bad
Thanks Boosted99Si
Hey HoodWinked, if you can't find someone to do an ECU for you(chip it for hondata). A friend of mine does them for a really good price.
.Thanks Boosted99Si
