how to release fuel pressure when install injectors
Old Aug 22, 2003 | 06:47 PM
2000vsm's Avatar
Default how to release fuel pressure when install injectors
How do i release fuel pressure when install injectors?
also do you guys run lean or rich with 450cc and vafc hack during IDLE and rpm before boost?
say your turbo boost kicks in at around 3000rpm.. so basically 0-3000 is in normal vacuum, do you run from 0 to 3000rpm same as idle settings or what?
Old Aug 22, 2003 | 06:53 PM
stinker504's Avatar
Pull fuel pump fues and turn on car....car will die when no more fuel. That's what my haynes manual said to do.
Old Aug 22, 2003 | 07:07 PM
2000vsm's Avatar
Default Re: (stinker504)
i guess my fuel cut off switch works the same...
Old Aug 22, 2003 | 07:14 PM
scttydb411's Avatar
you also need to open fuel cap afterward to help relieve extra pressure.
Old Aug 22, 2003 | 08:57 PM
2000vsm's Avatar
Default Re: (scttydb411)
ok fuel cap as well.. good, noted.
now please help me with the teflon paste.. i need that **** by monday
Old Aug 22, 2003 | 09:54 PM
BlueSi2k's Avatar
Default Re: (2000vsm)
the helms just says to open the fuel cap and loosen the banjo nut on the return line. Thats what i did...the fuel that was in the rail obviously came out but no problems.
onemore
Jul 13, 2008 11:56 AM
Shmaa
Jul 7, 2006 04:59 PM
midwesta
10
Aug 3, 2005 03:06 AM
austrian type-R
Apr 28, 2002 09:33 PM
