Taking about Axels to swap 32mm hub ends with 36mm hub ends, What tools/tips/tricks will I need to d
Old Aug 22, 2003 | 04:36 AM
.jacob's Avatar
Default Taking Apart Axels to swap 32mm hub end with 36mm hub end, What tools/tips/tricks will I need to d
Hi I have a JDM ITR 5 lug conversion on my Civic and I am taking apart the axels because my stock USDM hub has a 32mm spline and my JDM hub has a 36mm spline. I have the JDM ITR axels so all I know to know is how to take both sets apart and then reassemble them correctly. Will I be able to reuse the boots? Are there any parts I won't be able to reuse? Are there and special tools required? When rebuilding them what grease should I use, and how much?
Thanks,
Jake
Modified by Ninety2SiR at 2:56 PM 8/22/2003
Old Aug 22, 2003 | 11:08 AM
.jacob's Avatar
Default Re: Taking Apart Axels to swap 32mm hub end with 36mm hub end, What tools/tips/tricks will I need to
no one has ever taken apart an axel?
Old Aug 22, 2003 | 11:16 AM
1992Si's Avatar
Check out " The drive shaft shop" or I think Axles our us. maybe check out the add's in the back of car magazine for axle shop's.
I'm sure some one makes axles for what you want.
Old Aug 22, 2003 | 11:32 AM
.jacob's Avatar
Default Re: (smithby)
Thats but no thanks. I know it can be done, which is why I have both sets of axels. I am not looking to buy anything.
lsd96teg
Oct 18, 2010 08:26 PM
ls2typer15
Aug 19, 2008 07:07 PM
Myslowdc4
Suspension & Brakes
Oct 21, 2007 11:33 AM
Project99EK
Mar 13, 2004 09:04 AM
.jacob
Aug 25, 2003 06:28 AM
