Help Disassembling Axels and reassembling with different hub ends?
Hi I am installing a JDM ITR 5 lug conversion on my Civic and I am taking apart the axels because my stock USDM hub has a 32mm spline and my JDM hub has a 36mm spline. I have the JDM ITR axels so all I need to know is how to take both sets of axels apart and then reassemble them correctly. Will I be able to reuse the boots? Are there any parts I won't be able to reuse? Are there and special tools required? When rebuilding them what grease should I use, and how much?
Thanks,
Jake
Thanks,
Jake
Re: Help Disassembling Axels and reassembling with different hub ends? (Ninety2SiR)
if you are running a b-series, then you can use the 36mm axles without any issues as only the outer joints are changed.
if running d-series take the outer joints apart and slap the 36mm ones on. for instructions check your email .
Taking about Axels to swap 32mm hub ends with 36mm hub ends, What tools/tips/tricks will I need to d
.jacob
08-22-2003 11:32 AM
darkknightwong
07-18-2002 02:22 PM
