Need Help, can't start the motor!
Old Aug 22, 2003 | 03:40 AM
Darkteg's Avatar
New User
Default Need Help, can't start the motor!
the sparking plug test on top of the valve cover doesn't show any spark whatsoever,
the starter works fine, it cranks, i have fuel but no spark at all.
i've checked the blk/yel fat wire going to the distributor and it's got 12v, i've changed the whole distributor with a spare one i had, i even checked the Main Relay and it works fine.
the yel/grn wire from distrib. to the ecu A20 was also checked, no prob.
the cam timing is untouched, what else do i have to check?
Old Aug 22, 2003 | 08:25 AM
Darkteg's Avatar
New User
Default Re: Need Help, can't start the motor! (Darkteg)
anyone??
Old Aug 22, 2003 | 08:58 AM
kevinoneill's Avatar
It could be just a dying/faulty alternator/battery???
Old Aug 22, 2003 | 10:06 AM
Darkteg's Avatar
New User
Default Re: Need Help, can't start the motor! (issues4)
another battery was used, the alternator is almost brand new.
someone said it could also be a freaky thing from the imobilizer, but other than that what else can i check into?
Old Aug 22, 2003 | 12:18 PM
JimBlake's Avatar
Does the immobilizer shut down the spark? I though it only shut down the fuel injection...
Old Aug 22, 2003 | 01:41 PM
pj orquiz's Avatar
Default Re: Need Help, can't start the motor! (JimBlake)
your coil
Old Aug 25, 2003 | 10:08 AM
Darkteg's Avatar
New User
Default Re: Need Help, can't start the motor! (pj orquiz)
hmm, coil on two diff. distributors?
Old Aug 25, 2003 | 10:34 AM
im sabah's Avatar
1)did you check for continuity on the distributor wires?
2)do you have a good ground?
3)are the plugs new?
i bet its the ground...
Blazen_angles
May 23, 2012 08:02 AM
PapaMoose
27
Nov 19, 2011 03:00 PM
dirrtybirdy
Mar 28, 2010 01:43 PM
boosted b15
Dec 8, 2009 11:32 PM
1baddcivicsi
26
Oct 13, 2006 04:17 PM
