no spark
no spark
hey guys just wondering if any of you out there have any ideas of whats going on. So i have a built 92 civic with a d15 in it and i cant get any spark. the car drove fine then sat for two days now wont start. ive replaced the coil,icm,cap, rotor, plugs, wires, and a complete distributor and have had two working ecm's pluged in. both engine grounds are good and im lost for ideas.
Re: no spark
Does the fuel pump prime?
Does the Blk/Yel wire attached to the coil and igniter unit have battery voltage when the key is turned to ON(II)?
What voltage do you measure on the Yel/Grn wire attached to the igniter unit? Have you tested the Yel/Grn wire for a short or open?
Re: no spark
yes my coil has voltage and it reads 12.1 and only when the car is in the on possition like it should i think there might be a bad ground to my ecm but not sure the easy way to approch this matter if any.IDEAS
Re: no spark
yes fuel pump primes and my fuel pressure is fine
yel/grn reads 12.1v
and no have not tested for a short or open with the yel/grn
and that means its at least getting power but still no spark wich leads me to think a bad ground somewhere i tested volts and ressestence and every thing checks out other than ground from ecm
yel/grn reads 12.1v
stickman78114
06-20-2009 08:19 AM
1baddcivicsi
26
10-13-2006 04:17 PM
