frustration.... no vtec when warm
Old Aug 21, 2003 | 09:06 PM
ED8DX's Avatar
Default frustration.... no vtec when warm
ok this is a b20 block with a b16 head. It has a type-r oil pump. The only stock thing in the block is the crank and the oil pick up. It runs on a p28 and uses a fields controller for activation.
The problem... when the car is run for approximately 30 min vtec will cease to operate. All the lines, oil passages have been checked for obstructions, the solenoid was replaced for a known functioning one. It still occurs when the fields controller is off. It only happens when the car gets into operating temp.
Any help will be appreciated. Thanks
It doesn't seem to be electrical,
Old Aug 22, 2003 | 06:32 AM
ED8DX's Avatar
Default Re: frustration.... no vtec when warm (ED8DX)
Any one?
Old Aug 22, 2003 | 08:48 AM
Doctor CorteZ's Avatar
take Fields and throw in trash.
Old Aug 22, 2003 | 01:06 PM
GeeReg's Avatar
Default Re: frustration.... no vtec when warm (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">take Fields and throw in trash.</TD></TR></TABLE>
That was an ignorant statement. Not to mention unhelpful.
Old Aug 22, 2003 | 02:43 PM
MAX_CFM's Avatar
Default Re: frustration.... no vtec when warm (GeeReg)
change yur oil
Old Aug 22, 2003 | 02:49 PM
sinatra's Avatar
Hmm. Not a pro wit this but I don't think vtec is supposed to kick on when the engine is cold, atleast I have never heard it kick on. Maybe the wiring there is backwards, ie vtec on when cold and off when at running temp. Just an idea.
Old Aug 22, 2003 | 04:36 PM
Audi RS4's Avatar
Lover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeReg &raquo;</TD></TR><TR><TD CLASS="quote">
That was an ignorant statement. Not to mention unhelpful. </TD></TR></TABLE>
not an ignorant statement when it is fact. that **** sucks..........
Old Aug 22, 2003 | 06:24 PM
ED8DX's Avatar
Default Re: frustration.... no vtec when warm (AK1200)
The oil level was checked and was fine. When I said warm I mean that the car is already at operating temp, vtec works for a while then it begins to studder in and out of vtec. This happens only after the car has reached operating temp and has been there for some time. The car is not over-heating though. Oh and it happens regardless of the fields being connected
Old Aug 23, 2003 | 07:43 AM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">
I don't understand why everyone has a problem with it. It does what it was made to do. Nothing more, nothing less. Granted, I wouldn't buy one for $300 new, but when they can be had for $100 used, it's a cost effective way control fuel. Especially if your setup doesn't require anything more.
Old Aug 23, 2003 | 08:17 AM
sinatra's Avatar
Have you removed the fields controller and returned it back to how it was when it ran fine? When trouble shooting I always return the machine, car/computer/whatever back to the state it was when it ran fine and remove whatever I changed before the problem occured.
Old Aug 23, 2003 | 04:20 PM
ED8DX's Avatar
Default Re: frustration.... no vtec when warm (sinatra)
Yeah, tried that and it still occurs. No oil leaks, every thing seems to work.
It feels like vtec comes in and out, like oil pressure is oscillating up and down. The oil pump is new though.
Old Aug 24, 2003 | 10:43 PM
ED8DX's Avatar
I was thinkning it may be the oil pump but it's not. TTT
Old Aug 24, 2003 | 11:18 PM
4DeepCivic's Avatar
Check oil pressure at cold and operating temp.
Old Aug 25, 2003 | 04:44 AM
caliriptide's Avatar
Default Re: frustration.... no vtec when warm (4DeepCivic)
DUDE!
I just have the same problem this weekend!!!! Not sure though.
My motor did that this weekend to!! ran a can of motor flush through it and boom it works fine now...
Checked everything oil pressure was perfect. Solenoid was fine. I mean went through everything!!!!!!!!!! WTF still wasn't working!
So I mean it may be a shot in the dark....but I gave it a try. NOTE: I am running STOCK parts. Head I am running was the one that came with the motor, ECU fully stock.
Be sure to follow the directions if you do it&gt; 5 min flush. Change the oil & filter.
May want to get a pro's thought about this? But it sounds to me that you may not have the proper oil presure to operate VTEC. Need to find out that the head is getting the proper amount of presure, to little/ will not work. Hope I helped some.
Old Aug 25, 2003 | 06:45 AM
That was an ignorant statement. </TD></TR></TABLE>
it is a unit that is known to cause many problems for people , myself included , just because I was blunt doesnt mean its ignorant.
helpful when it fixes his problem.
Old Aug 25, 2003 | 08:08 PM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED8DX &raquo;</TD></TR><TR><TD CLASS="quote"> Oh and it happens regardless of the fields being connected</TD></TR></TABLE>
So how is throwing the Field away going to help?
silverskateEF9
Apr 29, 2008 04:05 AM
nekoabandoned
11
May 12, 2006 03:23 PM
Lauj87
Jun 28, 2005 11:46 AM
fabe85
Nov 27, 2004 11:30 PM
itr1235
Oct 12, 2004 10:56 PM
