Compression results....
Old Aug 21, 2003 | 11:42 AM
92TypeR's Avatar
FSAE
Default Compression results....
Ok, so when I first picked up the car in March, I did a compression test. The results were 220, 215, 215, 215. Now, the results are 215, 215, 210, 215. However, I am using a different tester. The numbers are engine hot @ WOT.
Would it help to do an engine cold test also?
Do these numbers still look good?
Can the different tester be the cause of the change in compression?
Thanks.
EDIT: The motor is stock except for drivetrain mods.
Old Aug 21, 2003 | 11:44 AM
RTW DC2R's Avatar
Default Re: Compression results.... (92TypeR)
You have nothing to worry about
I think you are supposed to do it on a warm/hot engine and not cold but I dont know why.
Old Aug 21, 2003 | 12:41 PM
98ITR#0020's Avatar
Default Re: Compression results.... (RTW DC2)
You do it on a warm engine so everything is expanded to operating conditions
Old Aug 21, 2003 | 01:28 PM
bus stop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
YES
YES
Old Aug 21, 2003 | 01:51 PM
92TypeR's Avatar
FSAE
Default Re: Compression results.... (WhosITR)
Thanks Oscar
I think I dont need to worry. +/- 5psi isn't a big deal anyways I suppose.
Type 56
Engine Machining & Assembly
Aug 13, 2017 06:34 PM
lude98SH
Dec 18, 2006 04:39 PM
snowblind7x
Apr 13, 2005 08:12 PM
dohcter g
17
Mar 23, 2005 07:47 PM
RACEPAK
Jun 12, 2004 01:29 PM
