car wont go in reverse?
Old Aug 20, 2003 | 08:04 PM
TuRbO_CrX_7o2's Avatar
Default car wont go in reverse?
i have a y1 tranny every gear goes in great but it wont go in reverse???
it will go in somtimes if i hold the rpm's @ 3,500 and foce it in..... no scraching or grinding noises.... i dont know what the problem is? i used 2 1/2 - 3 quarts of honda tranny fluid.... please help..........
Old Aug 20, 2003 | 09:35 PM
MrIllegalX's Avatar
no grinding noise when you do that? that's actually bad if you don't hear that noise if you're doing that. Looks like your gate has a problem opening.
Old Aug 20, 2003 | 11:15 PM
9redsi9's Avatar
Try to put it into 1st gear before u put it into reverse, see if that works
Old Aug 20, 2003 | 11:54 PM
5lugNinja's Avatar
Default Re: (9redsi9)
sounds like a bad synchro to me
Old Aug 21, 2003 | 12:51 AM
Kamin's Avatar
Default Re: (SpiNniNDubs)
first, thats WAY too much tranny fluid.
there is a filler plug behind (firewall side) the passenger side axle, put a pan under it and remove the bolt. all excess fluid will drain out.
but sounds like something is fucked inside the transmission.
Old Aug 21, 2003 | 12:59 PM
MrIllegalX's Avatar
speakin of goin in reverse, it took me 8 tries to put it into reverse today. gotta a little scared. i forgot about the syncro, good call
Old Aug 31, 2003 | 10:54 PM
acuracy90's Avatar
Default Re: (MrIllegalX)
Reverse doesn't have a synchro. At least the 90-93 transmissions don't.
Mike
Duck Sauce
Apr 29, 2008 11:34 PM
h23vtak
Aug 10, 2007 04:08 AM
ekdj
10
Jul 13, 2007 07:43 AM
globy123
Dec 25, 2006 09:24 AM
