Vafc question......
Old Aug 20, 2003 | 07:19 AM
genetsang's Avatar
Default Vafc question......
i was browsing around the features on my Vafc.... i saw the menu for the "VTi" and "VTo" options.... is says the feature was turned OFF.... i was just wondering whether it was suposed to be ON or OFF??? thanks
Old Aug 20, 2003 | 07:50 AM
genetsang's Avatar
Default Re: Vafc question...... (genetsang)
looked in the manual about the VTi and VTo feature. It didnt say much about it... i just bumped into it when i was browsing through the MOnitor function.. just want to know if it should be ON or OFF.... THanks.
Old Aug 20, 2003 | 09:09 AM
SI304's Avatar
That is your vtec engagement, it will say ON when you're in vtec. One setting is adjustable, and the other lets the ecu control vtec engagement(stock setting). Can't remember exactly, but thinking Vti is stock, and Vto is the adjustable.
I would recomend NOT messing with this.
Old Aug 20, 2003 | 09:38 AM
genetsang's Avatar
Default Re: Vafc question...... (SI304)
i didnt mess with it... i just stumbled across it.. so what you are saying it. when i hit vtec, VTo would say "ON", instead of "OFF" like how it is now when the car is idling?
Old Aug 20, 2003 | 12:02 PM
rotorhead70's Avatar
VTi = VTEC signal from ECU to VAFC. The indicator will reflect your stock settings.
VTo = VTEC signal from VAFC to Vtec solonoid. This is where you will see your custom settings reflected in the indicator
VTi = VTEC in
VTo = VTEC out
Old Aug 20, 2003 | 01:54 PM
SI304's Avatar
Yes, and thankyou rotorhead.
xelloss
Engine Management and Tuning
Oct 28, 2008 09:35 AM
BlackOnBlackTeggie
Nov 30, 2003 06:25 PM
TurboB18C1
Nov 25, 2002 06:11 PM
98R-1144
Nov 4, 2002 05:12 PM
EleanoR
Apr 17, 2002 06:06 PM
