CROWER ROD BEARING SIZES
Old Aug 20, 2003 | 07:09 AM
1bad-eg's Avatar
Default CROWER ROD BEARING SIZES
What's going everyone. Like the title says I need to know if Crower makes their rods all the same number for the gsr motor. Like Eagle does with their's. Example-eagle is a #3...match that to the letters on the crank...look in the service manual... get the color code for the bearing. My Crower rods have numbers on them...1234...are these the numbers I need to use or are they part an ID# of some sort. Please everyone, help me. Thankyou.
I did a search but I got mixed reviews on the topic
Old Aug 20, 2003 | 07:48 AM
1bad-eg's Avatar
Default Re: CROWER ROD BEARING SIZES (1bad-eg)
bump
Old Aug 21, 2003 | 02:51 PM
1bad-eg's Avatar
BUMP
Old Sep 12, 2003 | 09:55 PM
RAWB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad-eg &raquo;</TD></TR><TR><TD CLASS="quote">What's going everyone. Like the title says I need to know if Crower makes their rods all the same number for the gsr motor. Like Eagle does with their's. Example-eagle is a #3...match that to the letters on the crank...look in the service manual... get the color code for the bearing. My Crower rods have numbers on them...1234...are these the numbers I need to use or are they part an ID# of some sort. Please everyone, help me. Thankyou.
I did a search but I got mixed reviews on the topic</TD></TR></TABLE>
Old Sep 13, 2003 | 06:12 AM
Bnjmn's Avatar
Default Re: CROWER ROD BEARING SIZES (RAWB)
Crowers are sized to #2.
Old Sep 13, 2003 | 09:53 AM
FredoSP's Avatar
Default Re: CROWER ROD BEARING SIZES (Bnjmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">Crowers are sized to #2.</TD></TR></TABLE>
Thats the same for a B16 too?
Old Sep 13, 2003 | 02:05 PM
HotWheelz's Avatar
Default Re: CROWER ROD BEARING SIZES (FredoSP)
crower labelts them way so you see which cap goes with which rod. i had those rods.
used oem honda bearings per the crank code checked the clearances and were dead on.
Old Sep 13, 2003 | 02:12 PM
Kataku2K3's Avatar
It's easiest to have a complete set (all colors) when mic'ing your motor... We generally just start somewhere in the middle, green is a good start and plastigage it till you get the clearance you're shooting for... Don't worry about relying on the alphanumeric coding unless you don't want to buy a whole set of bearings... If you do, be sure to double check your clearances anyways... Peace
JakeSpec
Nov 24, 2007 12:37 PM
the.hamburglar
Feb 18, 2007 10:43 AM
djickabod
Dec 27, 2003 03:14 PM
00ITR #543
Feb 22, 2002 10:27 AM
SpeedMonkeyRacing
Feb 14, 2002 09:33 AM
