Tuning N20
Old Aug 19, 2003 | 09:08 PM
S13 slide's Avatar
Default Tuning N20
what exactly would you "tune" for a 75 shot on a higher comp engine?
reason i ask is because i have 10.8.1 comp B18B, crower 404's w/stock head...
i have a n.o.s. 75 shot wet kit in my room. do i take it to a dyno and tune my a/f ratio's?
when you pull timming/add more timming does that also affect your a/f ratio?
this would be my first engine i would be dyno tuning so any info on what i should look out for
when tuning would be great . thanks
Old Aug 19, 2003 | 10:39 PM
Furry in your eye
Guest
Posts: n/a
Default Re: Tuning N20 (S13 slide)
any reputable dyno should be able to do most of the tuning or at least point you in the right direction.
make sure you turn the dizzy back a few deg before you start to avoid detonation. usually retarding the timing will result in a slightly richer mix and advancing will lean it out slightly..
Enzo-Racing
Sep 19, 2010 06:18 PM
Beckerton
Engine Management and Tuning
14
Jun 30, 2010 10:35 AM
vladd
Feb 24, 2007 06:23 PM
Topdawgg
Jul 16, 2006 11:01 PM
pacifico
Aug 14, 2004 01:46 PM
