horn question
On my civic, I have three buttons, check all of them, if none of them work, the connector to the actuall horn (behind the front bumper) might be loose. If thes dont work, take the horn off the chassis and test it to the battery (one wire to each pole) if it doesn't work get a new one, if it does, fuses, or wiring is the problem.
at the horn button it should be negative trigger. jump it to ground see if it honks.
go right to the horn and jump it out. if it honks then you've got a problem up stream. if it doesnt then it may just be the horn itself. problem may also be the relay...
