horn question
Old Aug 18, 2003 | 12:51 PM
kliq's Avatar
Default horn question
car horn doesnt seem to work...i checked the fuse and its fine,
anything else that could be wrong?
almost got hit today
tia
Old Aug 18, 2003 | 03:12 PM
Torridcivic's Avatar
Default Re: horn question (kliq)
On my civic, I have three buttons, check all of them, if none of them work, the connector to the actuall horn (behind the front bumper) might be loose. If thes dont work, take the horn off the chassis and test it to the battery (one wire to each pole) if it doesn't work get a new one, if it does, fuses, or wiring is the problem.
Old Aug 19, 2003 | 02:55 AM
Dra6on45's Avatar
wut sound does your alarm make, if you have one, the last owner of my car hooked the alarm stright to the horn and my horn didnt work. jus my 0.02, its prolly jus a connection problem
Old Aug 19, 2003 | 06:51 AM
Xsi's Avatar
Xsi
Connect 12V straight to it and see if it goes, if not then get a new horn.
Old Aug 19, 2003 | 07:43 AM
nOOber's Avatar
Default Re: (Xsi)
at the horn button it should be negative trigger. jump it to ground see if it honks.
go right to the horn and jump it out. if it honks then you've got a problem up stream. if it doesnt then it may just be the horn itself. problem may also be the relay...
ayos ctr_hatch
Audio / Security / Video
Dec 23, 2008 11:52 PM
94 IntegraLS
Sep 17, 2007 05:29 PM
carbuff2000gs
Jul 17, 2007 05:08 AM
spoolinegsr
Nov 5, 2006 09:00 PM
Econo'Box
Mar 21, 2005 06:28 PM
