can't go past 7........
Old Aug 18, 2003 | 11:51 AM
RedRex8's Avatar
Default can't go past 7........
i thought that on a b16a1 it should go up to 8200 rpm stock, but mine will hit it's limit at 7000rpm any explainations????? by the way my ecu is a pr3.
Old Aug 18, 2003 | 12:06 PM
EL Vap133's Avatar
Default Re: can't go past 7........ (RedRex8)
Is your check engine light on?
Old Aug 18, 2003 | 12:52 PM
nautica_t's Avatar
Default Re: can't go past 7........ (Vap133)
your in vtec reservation mode.
i had that happen. but i got KS-R to fix it fo rme
he said that the wiring was done wrong.
but yeah do check for codes being thrown.
Old Aug 18, 2003 | 04:41 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
If you're just sitting in your driveway, it won't go past 7k...
Old Aug 19, 2003 | 12:10 AM
RedRex8's Avatar
yeah my check engine light comes on when i drive it for a while, but that is cause i don't have a clip to hold in a knock sensor. which the guy that did the swap for me said. So it is a wiring problem??
Old Aug 19, 2003 | 08:48 AM
EL Vap133's Avatar
Yes it kinda sounds like it. I know that on OBD0 B16's it won't let you go into vtec if your CEL light is on or if your oil is low or if your speedo cable isn't hooked up.
sky9
Dec 16, 2009 08:54 PM
EGThang
18
Jun 6, 2008 03:26 PM
lcjarrett
Feb 18, 2006 11:37 PM
TheIceMan
Dec 10, 2005 11:33 AM
Veil_Side_
Oct 9, 2001 06:26 AM
