check engine light
Old Dec 16, 2009 | 08:48 PM
sky9's Avatar
Default check engine light
hey i got this 89si with a 93ls swap. the check engine light seems to be going on as i driver in high rpm. or if i drive for a long time at speed of 35pmph+. check engine light turns off when i restart the car. any ideas? someone told me it could be a bad distributor.
Old Dec 16, 2009 | 08:54 PM
HONDRETTI's Avatar
Default Re: check engine light
if you read the FAQ, a section will guide you through the process of checking for ECU codes. this will tell you the cause of your CEL. sounds like your knock sensor.
03djmAccrd
15
Sep 25, 2010 04:33 PM
keegur
Acura TSX
Jan 10, 2009 01:33 PM
butter99
15
Dec 18, 2008 04:27 PM
1994CivicGS-R
Oct 9, 2005 06:25 PM
98teg
Oct 6, 2003 07:39 PM
