Final Mods, due to being dicked too many times....need some opinions/wisdom/info..
Old Aug 17, 2003 | 11:55 AM
MikeMAN's Avatar
Default Final Mods, due to being dicked too many times....need some opinions/wisdom/info..
Well the last shop that dicked me on my engine forgot 3 dowls and had 3 loose headbolts (costing me a SHITload of $$ to fix right now for a headgasket, sending the head to a machine shop..etc), so I think im getting a header, full exhaust, and possibly a hondata S100 (this is my question)..and calling it quits as far as the honda aftermarket goes. I am a college kid with little money and have been screwed over too many times. Would my setup benefit from a hondata? Would it make it more reliable?
thanks for ANY input you can give me.
mike
Old Aug 17, 2003 | 05:44 PM
Tweakmeister's Avatar
Default Re: Final Mods, due to being dicked too many times....need some opinions/wisdom/info.. (MikeMAN)
The best mod you can make is buying a Helms and reading. Don't be afraid to work on your engine and know it's done right
Hondata is one of the most powerful tuning tools out. Go for it
Old Aug 17, 2003 | 06:03 PM
laughinxxx's Avatar
New User
Default Re: Final Mods, due to being dicked too many times....need some opinions/wisdom/info.. (Tweakmeister
Yeah, it is definately time to start working on your own car. How fast do you want to go? Are you still running the low compression bottom end?
Old Aug 17, 2003 | 08:09 PM
MikeMAN's Avatar
i wanna START with mid-high 13's on street tires, and If im gunna start working on my own car, would it be advisable to get a cheap daily driver?
thanks guys,
mike
p.s. kris, hows AL?
Old Aug 17, 2003 | 08:29 PM
laughinxxx's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">i wanna START with mid-high 13's on street tires, and If im gunna start working on my own car, would it be advisable to get a cheap daily driver?
thanks guys,
mike
p.s. kris, hows AL?</TD></TR></TABLE>
A reliable daily driver is a very good idea.
How fast do you want to go once you are done with the car? Do you want to stay NA, add a bit of spray later, or go turbo? Once you figure that out build the bottom end to handle the amount of power that you desire and put in the correct compression pistons. Then get your bolt-ons or turbo set up. Finally do the head and cams.
If you are going to go NA just get a VAFC for now and pick up Hondata or whatever EMS you want when you are done with the motor.
Arkansas has fine girls, hot weather, and shitty cars. I've got a decent job and spend an hour or more at the gym every weekday, so I'm happy. My ******* landlord did try to evict me for having a shortblock and engine stand in my apartment though. Crazy bitch.
Old Aug 17, 2003 | 08:41 PM
MikeMAN's Avatar
lol..bitches bitches bitches hehe
how is the "learning" coming along with the motor?
mike
Old Aug 17, 2003 | 08:45 PM
MikeMAN's Avatar
forgot to post my goals:
consistant mid-high 12's, NITROUS beast...
im thinking my compression is good for this (*i know with tuning high compression isn't a big deal...but for me its an extra safeguard)
now, i believe my bottom end SHOULD be good stock, i need to work out tuning/nitrous kit options now (and kris, u can help with that im sure )
anyone else with input would be appreciated
(btw: are the b20 sleeves gunna be a problem?)
mike
Old Aug 18, 2003 | 07:42 AM
laughinxxx's Avatar
New User
So far I've learned that it takes a long time to save up enough money for parts and tools.
Do you want mid 12s on slicks or street tires(ie. BFG drag radials)?
With the low compression that you are running cams won't do much for you. So basically, you're looking at running your current motor, which is probably getting you to 14.5s and alot of spray. You can't spray enough on that stock bottom end to get you to 12s on street tires. And take it from me, having a quick car on the bottle and a slow one off the bottle sucks. Build a 13 second motor and then spray into the 12s. Shoot me a PM when you see this. Since you want to know what your options are for spraying this post won't serve much purpose in the NA forum.
Old Aug 18, 2003 | 10:52 PM
MikeMAN's Avatar
u got IM d00d!
mike
Old Aug 18, 2003 | 11:40 PM
snowseeker's Avatar
Where are you located? I see minnisconsin, (border)? I am in central WI. I do ALOT of work on the cars around here and neiboring states. If you need any help with anything anytime let me know.
Old Aug 19, 2003 | 09:17 PM
MikeMAN's Avatar
heya, i am in the milwaukee area (Burlington to be exact), if I got a set of pistons would you be willing to show/teach and lemme help install them?
thanks,
mike
Old Aug 19, 2003 | 10:24 PM
snowseeker's Avatar
Sure could. Just let me know when and where!
Old Aug 20, 2003 | 04:42 PM
MikeMAN's Avatar
you got pm
mike
p.s. update: 4 bolts were stripped in the block, need to be helicoiled.....thanks JDM!
Old Aug 23, 2003 | 11:11 AM
MikeMAN's Avatar
bump!
mike
Old Aug 25, 2003 | 08:38 PM
Accord94DX's Avatar
i just got this shipped from hong kong, if you need to use it lemme know:
Old Aug 25, 2003 | 08:58 PM
MikeMAN's Avatar
you got PM!
mike
lowtegsr
Jan 15, 2008 09:42 AM
95turbogsr
Jun 28, 2005 09:10 PM
Root79
Jan 27, 2005 01:02 PM
PM-Performance
Sep 25, 2003 10:37 AM
Full-Race Henry
May 14, 2003 03:10 PM
