lean at partial throttle w/engine management....ecu programers please help!
I am running a turbo charged setup with 450cc injectors and a zdyne engine management. the tune that i have made is great for boost, it runs a little richer than stoich, my guess is around 12 to 1 or so. my problem comes when my throttle is below the 15% that i set for the computer to run in closed loop.
should i run my ecu in open loop at all times? could this cause any damage? is there any other way to run a closed loop program that wouldn't lean out?
thanks guys!
thanks guys!
i just fixed my vacuum leak so that shouldn't be effecting anything. I'm just going to set my car to run in open loop starting at 0% throttle unless someone tells me its bad. thanks.......i know there are smart people on this forum, this one just might take a little more action upstairs
open loop means it's only adjusting fiel and spark by tps, map and rpm. This is good for tuning with a WB02 sensor on a dyno and thats about it. it shouldnt lean out unless your maps are telling it to
edit: run open loop when not under boost and low tps%, closed right befor boost and high tps%
VTgringo
Aug 18, 2003 06:50 AM
