physical mod to fit DSM injectors...
Old Aug 12, 2001 | 06:14 PM
paulzy's Avatar
Default physical mod to fit DSM injectors...
Is there any physical modifications to the injector bungs that you need to do to fit DSM injecotrs?
Old Aug 13, 2001 | 02:24 PM
paulzy's Avatar
Default Re: physical mod to fit DSM injectors... (Slow_ass_4dr)
nobody has done this mod yet? I know some of you guys already have.
Old Aug 13, 2001 | 02:36 PM
sgT's Avatar
sgT
the dsm injectors i have the std plugs on them. My rc plugs work fine.
If you mean manifold/rail fitment, mine go in fine there as well.
Old Aug 13, 2001 | 03:50 PM
paulzy's Avatar
Default Re: physical mod to fit DSM injectors... (sgT)
so they fit in the manifold and fuel rail just like any other honda injector would?
Old Aug 13, 2001 | 03:52 PM
dustin's Avatar
They should work just fine... keep in mind they are peak and hold.
Old Aug 13, 2001 | 05:07 PM
paulzy's Avatar
Default Re: physical mod to fit DSM injectors... (dustin)
yeah, I know that....they're just temporary on a haltech...can't afford Russ Collins yet...went broke on the motor.
Old Aug 13, 2001 | 10:21 PM
sgT's Avatar
sgT
yeah, they fit fine.
Old Aug 14, 2001 | 07:29 AM
boomslang's Avatar
What year dsm injectors fit?
Old Aug 14, 2001 | 09:46 AM
dbman96's Avatar
New User
Default Re: physical mod to fit DSM injectors... (Inlinefour)
All of them fit; just make sure you get the ones off a 5-speed turbo model; the automatics are only 350s instead of 450s. On my car it worked better on the injector/manifold seal to use the rubber seats that came with my RC injectors than the OEM ones; the RC seats are taller so they hold the DSM injectors a little better. I think the DSM injectors are almost IDENTICAL in size/shape to the RC injectors so I consider them to fit as good or better than the RCs. Where they plug into the fuel rail I suggest swapping the OEM o-rings in place of the DSM ones as well. The Honda o-rings are a bit thicker and look like they seal better.
Old Sep 2, 2001 | 08:09 PM
The Punisher's Avatar
Default Re: physical mod to fit DSM injectors... (dbman96)
I just wanted to let everyone know about this website I found about DSM injectors. http://www.dsm-performance.com/telcatalog.html Check it out. From what I am hearing, I am thinking of tossing the RC's and going with the DSM 750's for my Hondata reprogram.
dbman96, you said you are currently using DSM injectors, will the ones on the site I listed work for me? I plan on upgrading my fuel rail anyway, but I shouldn't have to modify it in anyway right? Thanks,
gsr*lude
Old Sep 2, 2001 | 08:42 PM
Zeus's Avatar
Default Re: physical mod to fit DSM injectors... (gsr*lude)
Very interesting Holley injectors... 5 hole squirters... now if I just didn't have to run a resistor pak... Just want to run the Hondata and some real big freakin' injectors...
Old Sep 2, 2001 | 09:04 PM
98hx99b18c's Avatar
Default Re: physical mod to fit DSM injectors... (Zeus)
Hmm...thats interesting I just got some 450cc off a 95 eclipse and they did not fit my obd1 injector plugs.
Old Sep 2, 2001 | 09:40 PM
That is where I luck out, Prelude injectors are peak and hold injectors!
Old Sep 3, 2001 | 07:41 AM
Zeus's Avatar
need some 720ccs or so though...
Old Sep 3, 2001 | 08:00 AM
Zeus, do you have any pictures of your car?
Old Sep 3, 2001 | 09:19 AM
Civic TSI's Avatar
Default Re: physical mod to fit DSM injectors... (98hx99b18c)
98hx99b18c: Just remove the plastic pin in the injector with a blade and they will fit your harness.
Old Sep 3, 2001 | 12:18 PM
Zeus's Avatar
which one?
092eg6
Dec 23, 2009 01:38 PM
mrx
Dec 18, 2004 03:57 AM
Wo-Nelly
Mar 2, 2004 07:30 AM
integrx
Dec 4, 2003 12:57 AM
move_right
Dec 22, 2002 07:45 AM
