Going Hondata, probably.... Need advice!
Old Aug 14, 2003 | 07:54 PM
Teg4e's Avatar
Default Going Hondata, probably.... Need advice!
Ok, it's been about a year of boosting on the drag-supplied "fuel system" of vortec 12:1 fmu, inline pump, and stock injectors. Fortunately, I now have the money to get some real tuning, and I think Hondata's the best/cheapest method. Here are a couple concerns/questions for you FI gurus:
1. What size injectors should I get? Later down the road, I'm looking to get 300-350whp out of my LS integra on pump gas. I'm first tuning on the stock block up to about 10psi or so, hoping to get 250whp, but later on I plan to build it to handle the 15-20psi for the 350whp. I've heard suggestions from reputable people as low as 370cc and up to 650cc.
2. What parts do I need exactly? Here's what I've come up with so far:
-OBDI, Hondata-chipped ecu
-OBDII--->OBDI harness
-Hondata program (if i get a hondata-chipped ecu, do i need this?)
-AEM, or other brand, rising rate 1:1 FPR
-Walbro 255lph intank fuel pump.
-GM 3 bar MAP sensor.
I want this car to be reliable as an everyday driver/occasional track use, but I don't need to be tuning this myself, or have any need for the datalogging, full throttle launch, etc. I think a barebones s200 system will give me what I need?
3. One more thing, my number 1 cylinder has a 35% leak in it. Should I address this problem first, before I go hondata or wait til it really becomes a problem?
tia, Ethan.
Modified by Teg4e at 5:52 PM 8/15/2003
Old Aug 14, 2003 | 08:02 PM
VaporTrail's Avatar
New User
Default Re: Going Hondata, probably.... Need advice! (Teg4e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teg4e &raquo;</TD></TR><TR><TD CLASS="quote"> What parts do I need exactly? Here's what I've come up with so far:
-OBDII---&gt;OBDI harness
You don't need a AEM regulator (hell those things are unreliable, no one needs one), the stock regulator is a 1:1 rise rate. You don't need the 3 bar right now, you can wait on that if you'd like. Everything else looks good, I'd recommend RC high impedence 550cc injectors for your application and project goals. Good luck
Old Aug 14, 2003 | 10:06 PM
11psiTurboSI's Avatar
What size injectors should I get? (550cc-720cc)
-OBDI, Hondata-chipped ecu--- (Yea)
-OBDII---&gt;OBDI harness--- (Yea)
-Hondata program (if i get a hondata-chipped ecu, do i need this?) (You need the s200 blue box)
-AEM, or other brand, rising rate 1:1 FPR ----(Yea)
-Walbro 255lph intank fuel pump.---(Higly Recommend)
-GM 3 bar MAP sensor.--- (Yea stock map can only read 11.2psi)
Old Aug 14, 2003 | 10:16 PM
Teg4e's Avatar
Default Re: Going Hondata, probably.... Need advice! (9psiTurboSI)
uh, so why do I need an aftermarket FPR if the stock one is 1:1?
Old Aug 14, 2003 | 10:32 PM
VaporTrail's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teg4e &raquo;</TD></TR><TR><TD CLASS="quote">uh, so why do I need an aftermarket FPR if the stock one is 1:1?</TD></TR></TABLE>
for applications up to and even exceeding 400whp, with correctly sized injectors, I often ask the same question
Old Aug 15, 2003 | 02:06 PM
Teg4e's Avatar
Default Re: Going Hondata, probably.... Need advice! (VaporTrail)
Old Aug 15, 2003 | 03:53 PM
madman604's Avatar
not to hijack, but Im using a B&M reulator. should i switch back to OEM? me under 300 hp
Dyelon
Jun 22, 2007 03:35 PM
96redgsr
May 16, 2005 12:44 PM
g2turbo
Nov 30, 2002 05:03 PM
flip1199
Aug 18, 2002 12:31 PM
Mikex25
Oct 30, 2001 09:50 PM
