greddy turbo kit w/ vafc
Old Aug 14, 2003 | 03:40 PM
ek_will's Avatar
Default greddy turbo kit w/ vafc
is it possible to run a stock greddy sohc kit with a v-afc instead of a bluebox, i had my e-manage stolen a couple days ago and need some type of fuel management and i thought this was good way to go since i can get it upgraded later. it will just be running at 5psi, any settings i can use in the meantime till i get it tuned?
Old Aug 14, 2003 | 03:43 PM
psileepR's Avatar
New User
Default Re: greddy turbo kit w/ vafc (dash0n)
you can use the vafc but you need at least 440 injectors...
Old Aug 14, 2003 | 05:57 PM
ek_will's Avatar
Default Re: greddy turbo kit w/ vafc (psileepR)
oh i see, does that mean i need a res. pack too? i dont know to much about the hack, injectors, and what not. this stuff hit me pretty hard so im still crammin
Old Aug 14, 2003 | 06:15 PM
95civicex's Avatar
If you get saturated injectors you don't need a resistor, if you get peak-hold injectors you do. For example, with dsm 450's you need a res. pack, with RC 440's you don't.
Old Aug 14, 2003 | 06:41 PM
ek_will's Avatar
Default Re: greddy turbo kit w/ vafc (95civicex)
oh i see then, so all i would need is these two items correct? vafc + saturated injectors injectors go right in? any mod needed?
edit: better yet someone give me a shopping list saturated injectors seem very costly.
Modified by dash0n at 7:54 PM 8/14/2003
Old Aug 14, 2003 | 07:20 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dash0n &raquo;</TD></TR><TR><TD CLASS="quote">edit: better yet someone give me a shopping list saturated injectors seem very costly.</TD></TR></TABLE>
AFC (SAFC or VAFC, either one)
DSM 450s
resistor box
You're done. Use the settings from The Drop Shop's webpage as a starting point and go from there.
Old Aug 14, 2003 | 07:41 PM
platinum00's Avatar
Default Re: greddy turbo kit w/ vafc (Daniel)
vafc - $300
dsm injectors 450cc $ 70
resistor box $30
that's all you need to run 9 - 10 psi.
have fun
platinum.
Old Aug 14, 2003 | 10:57 PM
spooned out's Avatar
so 310cc's + VAFC is not good? He is only running 5psi.
Old Aug 15, 2003 | 03:24 AM
platinum00's Avatar
Default Re: (spooned out)
i mean it can work. but for 70 bucks or so. why not do it the right way.
with 310's your not going to get anymore boost then you would with the blue box.
granted you can tune it a little, so that will make a little difference. Trust me though. there is a big difference from 6-7psi to 9-10psi.
platinum.
cxVtecC1
Oct 8, 2004 09:08 PM
jeremy.
Oct 18, 2003 10:36 AM
Turbo-JC
Jul 17, 2003 11:12 AM
SlamMan
Jun 9, 2003 08:53 PM
