greddy turbo kit w/ vafc
is it possible to run a stock greddy sohc kit with a v-afc instead of a bluebox, i had my e-manage stolen a couple days ago and need some type of fuel management and i thought this was good way to go since i can get it upgraded later. it will just be running at 5psi, any settings i can use in the meantime till i get it tuned?
Re: greddy turbo kit w/ vafc (psileepR)
oh i see, does that mean i need a res. pack too? i dont know to much about the hack, injectors, and what not. this stuff hit me pretty hard so im still crammin
Re: greddy turbo kit w/ vafc (dash0n)
If you get saturated injectors you don't need a resistor, if you get peak-hold injectors you do. For example, with dsm 450's you need a res. pack, with RC 440's you don't.
Re: greddy turbo kit w/ vafc (95civicex)
oh i see then, so all i would need is these two items correct? vafc + saturated injectors injectors go right in? any mod needed?
edit: better yet someone give me a shopping list saturated injectors seem very costly.
Modified by dash0n at 7:54 PM 8/14/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dash0n »</TD></TR><TR><TD CLASS="quote">edit: better yet someone give me a shopping list saturated injectors seem very costly.</TD></TR></TABLE>
AFC (SAFC or VAFC, either one)
DSM 450s
resistor box
You're done. Use the settings from The Drop Shop's webpage as a starting point and go from there.
DSM 450s
resistor box
Re: (spooned out)
i mean it can work. but for 70 bucks or so. why not do it the right way.
with 310's your not going to get anymore boost then you would with the blue box.
granted you can tune it a little, so that will make a little difference. Trust me though. there is a big difference from 6-7psi to 9-10psi.
platinum.
platinum.
SlamMan
06-09-2003 08:53 PM
