Art, or anyone, HP limit of this T3/T04B on a B18C1?
helping a friend put a T3/T04B on a B18C1, 9:1 c/r, standalone. The to4b compressor is a .60 a/r and the t3 turbine is a .63 a/r. Probably max boost level of around 15psi, maybe 20 depending on when this turbo runs out of steam.
thanks,
Jared
thanks,
Jared
Re: Art, or anyone, HP limit of this T3/T04B on a B18C1? (Jared)
on my exact same set up the T04b made 315 hp at 13 psi with only a few dyno passes. I switched it for a larger turbo since. I bet a healthy t04b in a gsr motor like you described will top out at just over the 400 hp mark at just over 20 psi.
T3/T04B smallest compressor wheel S trim, Stage 1 turbine wheeel .63 A/R made 370whp and 276ft-lb torque 21psi B16A stock bore well 81.5mm
integ22
09-11-2004 02:23 PM
