valve tap on mini me
Old Aug 14, 2003 | 03:38 PM
VTgringo's Avatar
Default valve tap on mini me
I got my engine running and i can here some valve tap at idle (800) and it gets even worse as i rev. I am running a zdyne ecu and i have a very conservative tune in there, i have also retarded my timing all the way and with the timing light i am at 16 BTDC. this engine was reciently rebuilt, could the valves not be adjusted properly? thanks guys
Old Aug 14, 2003 | 05:57 PM
MrTodd's Avatar
Default Re: valve tap on mini me (VTgringo)
Yeah it's the valve clearances. You're going to need to tighten the clearances.
Old Aug 14, 2003 | 06:45 PM
Ef Whore's Avatar
Default Re: valve tap on mini me (MrTodd)
More than likely the valves need a little tightening.....if that doesnt fix it, possibly you are hearing a fubarred bearing in the block.
Old Aug 14, 2003 | 07:53 PM
VTgringo's Avatar
Default Re: valve tap on mini me (Ef *****)
is it bad for my engine to run with valve tap or more of an annoyance? by the way i am boosting to about 10psi (not yet) as soon as the motor is running good.
Old Aug 14, 2003 | 08:04 PM
Blaze45's Avatar
Brrraaaap!
I would adjust the valves then see what it does... Are there new rings in there? Did you have to break em in?
Blaze
Old Aug 14, 2003 | 08:06 PM
VTgringo's Avatar
Default Re: valve tap on mini me (Blaze45)
yeah, new rings........any pointers on breaking in the rings. i hear there is the take it slow method and the "beat the **** out of it" method. which would you go with?
Old Aug 14, 2003 | 08:23 PM
Blaze45's Avatar
Brrraaaap!
http://www.mototuneusa.com/break_in_secrets.htm Check this link out....
and this one too
https://honda-tech.com/zerothread?id=487002
Blaze
Old Aug 14, 2003 | 08:36 PM
VTgringo's Avatar
thanks i really appreciate it......i just read the motoman's explaination...i think i'll go with that method. and i guess the boost will help seat the rings.
Old Aug 15, 2003 | 03:18 PM
VTgringo's Avatar
i heard it could also be the lost motion control tapping. anyone else heard of something like this in a mini me. thanks
civtic
Jan 14, 2008 01:47 PM
krazeenoy
Apr 6, 2007 12:49 AM
plikit
Dec 28, 2005 02:55 PM
kornerk12
Dec 18, 2005 03:27 PM
ken
Sep 25, 2001 04:06 AM
