What would be the purpose of this?
Old Aug 11, 2001 | 03:42 PM
S13Koop's Avatar
Default What would be the purpose of this?
Notice the wires coming off all four corners of the valve cover and one off of the dist. 3 going to the battery.
Any idea?
Old Aug 11, 2001 | 03:48 PM
BUSAFREAK's Avatar
Default Re: What would be the purpose of this? (winglessR)
I would guess he likes engine ground. Serves no purpose. He must of had extra wire and didnt know what to do with it..
Old Aug 11, 2001 | 03:49 PM
jteasy's Avatar
New User
I suppose they are grounds, the wires going to the battery are going to the negative terminal
Old Aug 11, 2001 | 03:50 PM
DutchITR1689's Avatar
It's stupid. They are just extra ground cables for the engine. Not necessary. You will create ground loops with this which could induce unwanted ground currents.....
Old Aug 11, 2001 | 03:57 PM
Type-ARR's Avatar
Default Re: What would be the purpose of this? (EuroITR1689)
If you guys think grounding the engine is not needed then cut the ground wire on your R and see what happens.........
Old Aug 11, 2001 | 04:00 PM
Default Re: What would be the purpose of this? (ITR-481)
You need 1 thick ground cable for the engine and 1 thick ground cable for the transmission. No more no less....
BUSAFREAK's Avatar
Who said ground isnt needed?? That's just overkill to put that many ground straps.
Old Aug 11, 2001 | 05:46 PM
utensil's Avatar
New User
Default Re: What would be the purpose of this? (ITR1162)
what does the ground wire do anyways?
Old Aug 11, 2001 | 05:50 PM
EG8R's Avatar
Default Re: What would be the purpose of this? (utensil)
it provides the negative side to the electric current through the car
and that is dumb, all those ground wires sheesh
Old Aug 11, 2001 | 07:50 PM
B18C-EJ1
Guest
Posts: n/a
No slick, we all think that 10 ground wires are a bit overkill..
Old Aug 11, 2001 | 10:55 PM
01ITR#700's Avatar
Default Re: What would be the purpose of this? (B18C-EJ1)
Had to be a combonation of extra cables laying around, boredom, a sense of humor, and a Digi Cam??
I have no idea.
M
Old Aug 11, 2001 | 11:19 PM
travis's Avatar
Default Re: What would be the purpose of this? (01ITR#700)
Ahhhh, the stuff dreams are made of...
...and B movies
Old Aug 12, 2001 | 07:20 AM
Mark27's Avatar
Translation from that website:
Recently you tried grounding the fashion. As for use wiring the 8sq for audio, when 3 are connected directly to the battery from the engine head, the power * torque impression improved clearly just this. When you connect near the light/write to in addition to, the light/write becomes bright, when you connect to such as engine compartment and the partition of the interior, it seems that is the various effects volume of audio becomes large and/or with depending upon the pot. Don't you think? in brief electric resistance becoming small, because it reaches the point where electric current flows efficiently it probably is what.
[Modified by Mark27, 8:20 AM 8/12/2001]
Old Aug 12, 2001 | 09:07 AM
S13Koop's Avatar
Default Re: What would be the purpose of this? (Mark27)
wow, thanks Mark27! Although it still seems a bit choppy.
Old Aug 12, 2001 | 10:35 AM
evil vapor's Avatar
you'd ground to the chassis, not the battery.
Old Aug 12, 2001 | 10:56 AM
Mark27's Avatar
Default Re: What would be the purpose of this? (vaporsi)
ahem.. forgot to mention that it's not my translation work.
I used babblefish
Here is one of the companies that manufactures these kits:
http://www.takakaira.com/performance/tmworks/main.html
Old Aug 12, 2001 | 04:21 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
that's nothing, i have 3 power cables going from my positive battery terminal to my starter, makes is start faster.....
90Rexx
Aug 25, 2009 12:00 PM
TravisB16a
May 16, 2008 05:27 PM
sanegb16
Aug 21, 2007 07:10 PM
davejj40
Sep 9, 2004 11:40 AM
BlendedEJ8
Apr 25, 2003 06:40 AM
